Old 09-03-2010, 04:32 PM   #21 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
I might not be exact with my numbers here but they will be pretty close.
If you have a 1hp motor turning an alternator/generator that motor should be drawing around 850-900 watts and the alternator should be putting out around 600-650 watts, so if you can make a 1hp motor that only draws 100 watts then it should be able to power an alternator and produce that same 600-650 watts, but you can't, it just doesn't work that way.
Old 09-03-2010, 06:27 PM   #22 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
That was a sad video, didn't demonstrate anything conclusive or useful, it didn't make the motor do any measured amount of work with a measured amount of power. Not even a diagram of the "concept". Comments are disabled because it would get torn up for being such a piece of B.S.
Without measuring both input and output power you cannot tell how efficient it is. This guy does not strike me as a scientist.
1hp=746 watts. This is not a measure of efficiency, just a conversion factor.
If the motor had zero back emf, would it not keep speeding up till it disintegrated?
Looks pretty steady state to me. Thar be back EMF in that motor.
Old 09-08-2010, 07:44 PM   #23 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 40.29 mpg (US)
Originally Posted by The Atomic Ass View Post
That's what I've been told, but how did science come to that conclusion? What basis of experiment returned the unerring result of ~746 watts to generate one horsepower?
Anyone mind if I bump this question?
Old 09-08-2010, 08:31 PM   #24 (permalink)
dcb
needs more cowbell
dcb's Avatar
Watt Watt noun [ From the distinguished mechanician and scientist, James Watt .] (Physics) A unit of power or activity equal to 10^7 C.G.S. units of power, or to work done at the rate of one joule a second. An English horse power is approximately equal to 746 watts.
He might as well argue that he is using inches that are not 25.4 mm.
Old 09-09-2010, 08:31 AM   #25 (permalink)
Its my understanding that the back-EMF is not actually wasteful, it simply reduces power output. As the back EMF starts, it slows current through the coils and therefore less power is drawn during that time. The power is not lost to nothingness.
Old 09-09-2010, 09:59 AM   #26 (permalink)
Wiki Writer
bugler - '91 Mazda 626
90 day: 35.89 mpg (US)
Right you are daox,
the back EMF is also the same effect used in generators to make electricity, its not a bad thing to have back EMF
Old 09-22-2010, 06:01 PM   #27 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
To boil it down conclusively, back EMF is fundamental to the electric motors operation. You cannot get rid of it and still have a motor.
Old 09-23-2010, 04:44 PM   #28 (permalink)
...beats walking...
...Counter Electro-Motive Force (CEMF) -- it does not matter *how* a wire is moved through a magnetic field (motor = pulled through the field; generator = pushed through the field), only that wire-through-field movement occurs.
...CEMF is *how* regeneration-charging occurs during braking.
HELP - DIY AC conversion to steady flow DC ElectricSquid DIY / How-to 13 01-15-2021 11:03 AM
going back to VX roots from D15B soch vtec Nden Introductions 14 05-19-2008 02:35 AM
Do Metros have back seat belts & do child seats need to be installed on a seat Wayneburg General Efficiency Discussion 8 05-07-2008 01:11 PM
Back to cycling zjrog Alternative Transportation 6 02-21-2008 11:42 AM
AC Induction Motor used as Brushless DC? WaxyChicken Fossil Fuel Free 5 01-29-2008 09:26 PM
