Old 07-26-2008, 07:38 AM   #11 (permalink)
VIVA LA MPG RESISTANCE
Will's Avatar
Meat-roll - '97 Metro
90 day: 55.4 mpg (US)
Wife's Brruik - '03 Century
90 day: 30.84 mpg (US)
Blue Balt - '08 Cobalt XFE
Team Chevy
90 day: 38.19 mpg (US)
Originally Posted by SuperTrooper View Post
The most comprehensive list I've seen for vehicles that CAN be flat towed is Motorhome Magazine's towing guide:
Dinghy Towing Basics
The Tundra is NOT on the list for 2007 vehicles.
Uh is this for towing a Tundra behind an RV, or towing an RV behind a Tundra?
Old 07-26-2008, 10:34 AM   #12 (permalink)
I wonder if anyone ever uses the towed vehicle to add power for accelerating? Ie, when pulling into traffic or going up a hill, the towed vehicle starts up and adds power, then shuts off the engine.
In theory, this would allow one to use a smaller more efficient engine on the towing vehicle.
Old 07-26-2008, 11:50 AM   #13 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
That would be an awesome idea for RV'ers, the problem is that the dingy would have to be automatic and probably the size of a full size truck in order to move an rv from 0- whatever. I can't see a yaris making much ground on a full size bus RV ..LOL
Then of course you have 99.9 percent of all automatic tranny's can't be towed behind an RV.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 07-26-2008, 12:39 PM   #14 (permalink)
Good point - the wheels on the towed vehicle would need a freewheel/ratchet installed - it can then push forward, but when turned off, the transmission wouldn't move.
Would be useful even if the towed vehicle was just accelerating its own weight.
Old 07-26-2008, 04:17 PM   #15 (permalink)
adrive7's Avatar
Ranger - '08 Ranger XL
90 day: 20.73 mpg (US)
Send a message via AIM to adrive7
I tried EOCing in my 2005 Chevy Cobalt once, and despite it being on that dinghy towable list, I won't be trying it again. I was on a long down-sloping stretch of country road with nobody around, so I popped it into neutral and shut the engine off. I was rolling at about 40mph, brakes and steering felt ok, so I kept going until I got to the stop sign at the bottom of the hill. I kicked the engine back on so I had my power brakes back and came to a stop at the sign.
When I pulled away from the stop the car was acting like a manual trans. with very poor clutch work. Shifts were hard and jerky, and coming to a stop the RPMs would drop to around 500 shaking the whole car before it popped out of gear. It did this the rest of the way home. The car sat for about 30 minutes before I needed it again and the problem was gone, I think it just drained too much fluid from the torque converter, and it never got a chance to refill, or something. I don't know all that much about transmissions. It hasn't been a problem since then (3 months).
Ohio State Baja SAE
Old 07-26-2008, 04:27 PM   #16 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
90 day: 42.72 mpg (US)
How long did you EOC adrive? Good to hear nothing bad happened permanently.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 07-26-2008, 04:33 PM   #17 (permalink)
adrive7's Avatar
It was probably .75-1 mile tops.
Ohio State Baja SAE
Old 07-26-2008, 09:19 PM   #18 (permalink)
texanidiot25's Avatar
Formula - '96 Formula/Trans-Am
90 day: 19.31 mpg (US)
Your service manager probably wants your money when you burn up the tranny.
The tranny gets it's lubrication pumped from the spinning of the engine. When you put it in N and shut off the engine, the drive shaft is still spinning gears inside the tranny. This is why in manuals they say the car should never be towed above 25-30 mph for short distances in N with out the drive shaft pulled out.
Leaving the engine on and coasting in my '90 Firebird along with other driving style changes shot from an average 12 mpg to 20 mpg. Keep the engine on and keep cash in your pocket.
Lets see how far it can go
"All I know about music is that not many people ever really hear it. [...] But the man who creates the music is hearing something else, is dealing with the roar rising from the void and imposing order on it as it hits the air. What is evoked in him, then, is of another order, more terrible because it has no words, and triumphant, too, for the same reason. And his triumph, when he triumphs, is ours." -Sonny's Blues
Old 07-26-2008, 11:29 PM   #19 (permalink)
Future EV Owner
Wannabe - '05 Civic LX
90 day: 40.53 mpg (US)
You guys are freakin' me out about the EOC.
Old 07-27-2008, 12:45 AM   #20 (permalink)
Slow and easy
elhigh's Avatar
Josie - '87 Pickup
90 day: 30 mpg (US)
I read a couple of days ago that Ford's next version of - I think it was the Fusion - will be flat-towed capable.
You're not in front of me...
I'm 25,000 miles in front of you.
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 05:04 AM
Best MPG with EOC & without EOC xbUser Hypermiling / EcoDriver's Ed 21 08-22-2008 12:25 AM
My auto transmission is clunky! Help! bennelson Off-Topic Tech 6 03-14-2008 06:50 PM
transmission determination - how to determine final drive ratio? gwahir EcoModding Central 5 01-12-2008 12:41 AM
