Old 01-11-2009, 01:10 AM   #21 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
5.06v is great. Who knows, it could have been either problem you mentioned. But at least now it sounds like youre in business.
Winter daily driver, parked most days right now
Summer daily driver
Old 01-11-2009, 03:30 PM   #22 (permalink)
Wingmn's Avatar
93 SL2 Auto - '93 SL2
90 day: 34.55 mpg (US)
09 Outlook FWD - '09 Outlook XR
90 day: 21.07 mpg (US)
Oh yeah! In business indeed - I'm pretty sure I could have used the other side pads on the LCD (run jumper wires from the header pins to the other side) and it would work, I might try it later if I get REALLY bored
I did some through hole continuity checks on the old LCD, and I had a few more pads that did not have continuity through them, but all the pads on the opposite side of the LCD were good... *shrug* I won't throw that LCD away for now.
Old 01-14-2009, 03:24 PM   #23 (permalink)
Wingmn's Avatar
Well - after 40 miles - not a hick-up. Solid as a rock!
It's a shame that besides the bad voltage regulator, that all my other problems were self induced
Old 01-25-2009, 10:25 PM   #24 (permalink)
americasfuture2k's Avatar
SLOLANE - '08 Aveo5 SV
90 day: 30.55 mpg (US)
i now have this problem. but its different. mine was working before as you all have seen. i still can cycle through all the brightness levels. and if i tilt my screen at a very sharp angle, i can sorta read the display. anyone have an idea of what the problem could be?
bah damnit. nevermind. its working now. something must be loose. damn. well i kinda dont want to yank it apart unless it happens again. the case i mean.
If you cant fix it with a hammer, then you have an electrical problem
http://www.cardomain.com/ride/3159589
shutup, im working on it
Old 01-25-2009, 10:29 PM   #25 (permalink)
Wingmn's Avatar
Can you adjust the contrast at all?
Old 01-25-2009, 10:32 PM   #26 (permalink)
yea i could. i got it working now. electronics are funny on operation. and im an electronic tech..... a mystery in life....
Old 01-26-2009, 03:10 PM   #27 (permalink)
Wingmn's Avatar
Anything in particular you did to get it working?
Old 02-06-2009, 07:27 PM   #28 (permalink)
i figured out what happened the first time. i had it plugged into a hub that wasnt powered. powered the hub, and the display lit up light it should.
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 999 12-14-2011 01:18 PM
MPGuino lcd help? gascort OpenGauge / MPGuino FE computer 5 12-08-2008 12:48 AM
Got my MPGuino Working! Nevyn OpenGauge / MPGuino FE computer 0 12-07-2008 05:38 PM
2x16 LCD Display issues/discussion dcb OpenGauge / MPGuino FE computer 29 08-19-2008 08:25 PM
