10-01-2009, 01:37 PM
No energy savings with 35watt HID's !!!!
So I heard a rumor that all aftermarket 35 watt hid's simply have a resistor to output 35 watts- this means the system is still using 50 watts because of the resistor.
In other words, your better off going with 55 watt hid's because you get all the wattage in light output instead of light+heat in the 35 watt hid's.
Thoughts? True or not? Anyone that can test this in their car if You have aftermarket hid's?
10-01-2009, 01:53 PM
LOL no
Not true.
10-01-2009, 02:52 PM
Moderate your Moderation.
Normally, when someone asks a question such as this, and you answer it, you'd do so with a reference...
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
10-01-2009, 03:43 PM
Well the reasoning behind it is to fool the cars ecu into telling it that there is still a bulb there (since it's using less watts some cars might throw a code).
Again, just rumors I've never actually tested a ballast before with a multimeter.
10-01-2009, 04:01 PM
Left Lane Ecodriver
Well, you need a question mark instead of four exclamations in the title, but I couldn't imagine a 3A headlamp in place of a 5.5A one would create any problems bigger than a "bulb out" warning light. Maybe some HID makers install a resistor to draw extra current, but I doubt it. Write to the manufacturer you're thinking of buying from, then post their response here. I do know the fancy headlamps on the Prius draw less than 55W, which proves that such lamps are out there.
10-01-2009, 04:21 PM
*blink* *blink*
Headlights are basically just a simple DC circuit... Think V = I x R and P = V x I
The 35W lights should have higher resistance which means lower amps. Power is thus reduced because the amps are lower, the voltage has stayed the same (nominally 12V).
However, in the grand scheme of things, it's almost irrelevant. Saving 20 watts x two lights is 40 watts. 745watts per hp, so you're saving a whopping .05hp by switching lights. I'd rather have the better lighting.
Mike
10-01-2009, 05:14 PM
Why would anyone need a bulb out idiot light. Looking out the windsheild and half the road is dark is a pretty good indicator.
10-01-2009, 05:18 PM
People are becoming dumber and dumber every year, that's why.
10-01-2009, 05:22 PM
#9 (permalink)
It's not so much an idiot light, but that the ECU will note a fault code if a circuit's not measuring up as expected.
It's an engineer's mind on thoroughness, when they already include an ECU code for high/low/no voltage on engine sensors, to extend the same to other circuits on the car.
Current mod: Skidplate/Undertray for my MkIV Jetta. Next mod: CAD drawing for skidplate so other Jetta/Golf drivers can make one too!
