Old 09-29-2009, 06:11 PM   #11 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
Always test adhesive tricks in an inconspicuous spot. Results can be greatly affected by residual mold release and other surface contamination. For a temporary bond, you might try using wax on the surface first. A thick, flexible adhesive between two rigid parts will hold well even with poor surface adhesion, and then can be cut in order to peel off the residue.
Old 09-29-2009, 11:03 PM   #12 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Glue will never work. By time you are done experimenting with adhesives, you will find none of them work for something like that. I would find a place under the dash where there is already a screw holding the trim on, remove it and install the bracket there. You might have to drill one extra hole, but it would not be obvious.
Old 12-11-2011, 06:29 AM   #13 (permalink)
Glue Connecters in the back of my computers
I know this thread is about fastening CB's to a vehicle but I've been searching for a way the non permanently glue leads into the back of my computer. would any of the suggestions on this tread work for this or does anyone know of a way to do it
I'm a DJ and I use mobile kit and the leads are always coming out of the back of the computer and It's driving me mad
Old 12-11-2011, 10:19 AM   #14 (permalink)
one of thOOOse people
twitchy - '98 civic dx + sir + ls
90 day: 33.35 mpg (US)
My first thought for that would be one permanent clip or loop glued or screwed to the back and replaceable zip ties holding the cables to it. I'm guessing the issue is strain relief. If you can bundle the cables and zip tie them to anything near the computer to keep the tension off the plugs.
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 03:03 PM
Project: making a permanent Metro Kammback extension MetroMPG Aerodynamics 251 12-02-2011 02:24 AM
Permanent Grill Block Raysp30 Aerodynamics 7 10-04-2011 01:30 AM
magnets use for permanent mods ? groar EcoModding Central 5 09-08-2008 04:52 PM
Corplast glue? Otto Aerodynamics 16 09-04-2008 05:04 PM
