Old 09-27-2011, 05:49 AM   #1 (permalink)
Engineering first
bwilson4web's Avatar
03 Prius - '03 Prius
90 day: 52.67 mpg (US)
10 Prius - '010 Prius III
90 day: 53.31 mpg (US)
Non-standard thread?
Hi,
I need to make an adapter for this rotary tool but the thread has me stumped:
The scale is 1/32 and my lying eyes say the pitch is ~31.5 threads/inch. Converting to metric, 1.279 threads/mm. The diameter is 5/16 inch, 7.9375 mm.
The diameter reads SAE but I can't find any standard thread that matches this threaded shaft. The problem is my adapter needs to screw on the shaft but this does not look like any standard tap would work. I need a tap to make the part.
Right now, it looks like I'll have to turn my own tap (I have access to a lathe at the autoshop.) The reason is finding a tool bit to cut the interior is not a trivial problem given the I.D. is going to be 5/16 inch, 0.3125" (7.9375 mm.) Fortunately, the adapter part will be aluminum so I can make a tap using steel stock; cut the threads; grind gaps for shavings, and; heat treat to harden.
The shaft is hollow but the I.D. is 0.1945" (4.9403 mm) and I need a shaft of 0.250" (6.35 mm.)
Thanks,
Bob Wilson
Local record
Old 09-27-2011, 06:37 AM   #2 (permalink)
JethroBodine's Avatar
Franken-Jetta - '90 Jetta GL
90 day: 51.61 mpg (US)
Starcruiser - '98 Pathfinder 4WD
90 day: 18.82 mpg (US)
Would that put it in tolerances for 8mmx1.25? I've run into some threads that need to be "finessed" to fit in standard thread pitches. Manufacturing standards aren't what they used to be.
Number 7 on the current POE list at last fill.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
Bonneville or Bust 2012
Old 09-27-2011, 08:30 AM   #3 (permalink)
Engineering first
I think you've nailed it . . . I had put together a spreadsheet but it had an error that kept me from seeing it. Once the error was fixed:
  • 1.4% - diameter error, small
  • 3.8% - pitch error, long
Thanks!
Bob Wilson
Local record
The Following User Says Thank You to bwilson4web For This Useful Post:
JethroBodine (09-27-2011)
Old 10-03-2011, 12:36 PM   #4 (permalink)
Could it be a Whitworth thread? Mostly found in British stuff prior to the 1960s: British Standard Whitworth - Wikipedia, the free encyclopedia
Old 10-03-2011, 01:29 PM   #5 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Ram 2500 ST Quad Cab 2wd, short bed
90 day: 33.32 mpg (US)
It's not clear to me what that male thread is attached to, but if you can, why not just take in to the harware store with you? Go over to the bins of nuts. Try your best guesses until something threads on easily by hand. Most stores carry all the standard SAE & metric sizes. That's usually my solution to this kind of thing.
Diesel Dave
~Life is an optimization problem.~
~Who says that just because your vehicle weighs over 3 tons that you can't get good mileage?~
