Old 08-19-2009, 03:55 PM   #21 (permalink)
"Inconceivable"
moorecomp's Avatar
My ZX2 - '99 Escort ZX2
Team ZX2
90 day: 40.5 mpg (US)
Her RAV4 - '011 Rav4 4x4
90 day: 24.98 mpg (US)
Man, I gotta tell ya, on my ZX2, I tried cutting the cam position sensor (did not work), crank position sensor (did not work), ignition (worked - but the unburnt fuel going into the catalytic converter caused a check engine light due to the O2 levels being wacked out), finally I tried the same method you did. Works like a champ. And when I bump start, it starts faster than if I used the starter. I have had this on my car for going on a year now and use it a lot (30-40 times a day). I get no check engine lights (other than the normal ones that go out after the engine restarts). I was just posting about this on another thread. Check this post for insight into my install.
http://ecomodder.com/forum/122284-post213.html
Works for me!
moorecomp
Mancelona, MI
Old 08-29-2009, 11:29 AM   #22 (permalink)
Draco - '89 F150 ext cab shrt bed XLT Lariat
90 day: 16.45 mpg (US)
without researching anything I just added a push pull sw into the ignition circuit, same as turning the key off. No check engine lights and smooth instant restarts, however sometimes during the restart it idles very high for a few seconds.
Reading what others have done makes me wonder if I should cut fuel rather than spark.
Vehicle is an 1989 F150 4.9 5 spd.
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 38 03-29-2012 04:53 PM
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 12:59 PM
[CRXMPG Mailbag] Radiator Fan Switch SVOboy EcoModding Central 10 04-14-2011 05:25 AM
Geo Metro Kill Switch Idea? HotRod EcoModding Central 5 01-27-2011 06:13 PM
Winter mod - heater blower integrated with engine kill switch MetroMPG EcoModding Central 3 12-31-2007 10:31 PM
