Old 08-28-2008, 01:26 PM   #11 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
Scangauge will monitor while the engine is off if you set the fuel type to Hybrid.
Putting it in neutral is usually a good thing - the engine is turning at idle rpm, below 1000, instead of much higher and burning extra gas just to keep itself turning over.
I don't know how your CVT likes EOC. Check the manual's instructions about towing.
It's not dangerous if you're not foolish. Obviously, try it out in a quiet place first. Hybrids like yours have electric power brakes and steering, so those work just as well with the engine off.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 08-28-2008, 01:32 PM   #12 (permalink)
Enthusiast Kinda
2005 HCH - '05 Civic Hybrid XL
90 day: 46.19 mpg (US)
Send a message via MSN to MasterAlex
Mine doesn't, brakes and steering go when the power is cut.
Also, just so I know what to look for, when talking about towing, i should see if it will allow it to????
Old 08-28-2008, 01:36 PM   #13 (permalink)
Here's an example from my 2004 Odyssey. 4 wheels on the ground towing is allowed below 35mph and for up to 50 miles. Anything below those marks is fair game for EOC.
Some will simply say you must tow it on a dolly, or only at "low speeds for a short distance". In that case, you don't want to EOC, except maybe rolling up to a stop.
Ah, sorry about that. I must be thinking of the 06+ version, then. I believe the Insight has electric as well.
That said, they do both work, it's just a matter of being harder work on your part. Some are worse than others. My civic's steering is almost the same, while my Odyssey has Incredible Hulk steering with EOC. Brakes on both are good for 3-4 applications, then they start going the Hulk path themselves. I make sure I don't get into that situation by leaving myself a reserve or by restarting if I start running low.
Old 08-28-2008, 02:48 PM   #14 (permalink)
2) coasting in neutral, engine idling;
3) regenerative coasting (hybrid vehicles)
4) regenerative braking (hybrid vehicles)
I disagree. #3 should be more efficient than #2, under most circumstances. If you are coasting in neutral with the engine idling, you are still using fuel. If you're doing regen, you usually (unless it's cold, when the ECU tries to keep engine temps up) will be in fuel cutoff mode, using no fuel AND getting some charge in the battery.
Of course this may vary depending on terrain, too. Even with full regen, a 6% downgrade will put me over 60 mph.
Old 08-28-2008, 02:51 PM   #15 (permalink)
Well, a 6% downgrade is pretty severe. The nearest one of those to me is a good 1000 miles away!
You also have to balance out the lost momentum from regen against the power reclaimed. On the much more common flat-ish land, coasting comes out ahead for this very reason. You do use a little fuel idling the engine, but it's more than counteracted by the momentum not lost to engine braking.
Old 08-28-2008, 11:55 PM   #16 (permalink)
Which shows the problem with a general statement like that list. Maybe true in the flatlands (I don't have enough experience to say), but most definitely not true in these parts :-)
Old 08-29-2008, 10:22 AM   #17 (permalink)
Enthusiast Kinda
I was doing some tests and I found that with the HCH1 the regen only occurs when the engine is on and in drive. IF the engine is on it will find the correct gear for that speed. So basically putting it in neutral is good unless you are going slow enough for the car to realize that it was going slow to put it in neutral.
Does that make sense?
Toyota addresses EMF health concerns with hybrids SVOboy EcoModding Central 31 10-16-2009 11:08 PM
I created a fantasy football league in yahoo sports. coastertoasterxb The Lounge 6 09-03-2008 10:35 PM
Are Biofuel hybrids a silver bullet? Indianapolis500 Fossil Fuel Free 8 07-31-2008 12:32 AM
GM thinks 1/3rd of its cars sold in 7 years will be hybrids SVOboy General Efficiency Discussion 10 03-20-2008 04:27 PM
Plug-in Hybrids Worse for the Environment? SVOboy Fossil Fuel Free 9 03-01-2008 09:42 AM
