Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 02-22-2009, 11:37 PM   #1 (permalink)
02 Golf TDI Driver
The Golf - '02 Golf GLS TDI
Last 3: 57.98 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Not Totally Green
But Greenish + Totally cool.
My dad has been wanting a classic motorized bike forever, I tried to do an Electric for him, but he didn't like it. So I got him one of these 80CC MOTOR BICYCLE ENGINE KIT MOTORIZED BIKE GAS MOPEd - eBay (item 190286734460 end time Feb-22-09 21:07:44 PST) for his 56 Hawthorn.
I just got it up and running yesterday; I need to modify the chain guard to clear the motor, install the second chain guard (paint it first) and install the front disc brake I got off of the bike that became my electric bike, find some nice period pedals, a nice period Seat, and most importantly build a more attractive fuel tank.
It has killer torque, feels stupid fast, will spin the rear tire in the grass, has an effective top speed of 26 mph (Iphone GPS), sounds "cool" and most importantly is FUN FUN FUN to ride. I'd love to see what MPG it gets, but there is (and will be) no instrumentation on board.
Anyways Here's a pic
Old 02-23-2009, 12:10 AM   #2 (permalink)
ECO-Evolution
Lazarus's Avatar
Days of Yore - '98 E-Bike
90 day: 4979.53 mpg (US)
Nice job. Do you need the pedals hooked to the chain? Won't they be spinning crazy fast or is that freewheeling hub?
No I believe you, just show me a source please
Old 02-23-2009, 05:28 AM   #3 (permalink)
Tobaloula Rusttbukkitt - '95 Ax Elation
90 day: 44.11 mpg (US)
I would really hope that that's a freewheeling hub, would be bloody dangerous otherwise.
Old 02-23-2009, 08:21 AM   #4 (permalink)
dcb
Don't Panic
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Did they tell you what the EPA certification number was?
"I kicked a giant mouse in the butt! Do I have to draw you a diagram?"
Old 02-23-2009, 09:25 AM   #5 (permalink)
02 Golf TDI Driver
There are actually 2 chains on the bike now. 1 Un-interrupted Factory chain with pedals and another with a sprocket clamped to the opposite side of the rear wheel (Which works surprisingly well.).
Old 02-23-2009, 09:27 AM   #6 (permalink)
02 Golf TDI Driver
The Factory free wheel (pedal) stays put.
The motor does not free-wheel, but it has a hand operated clutch.
Old 02-23-2009, 09:28 AM   #7 (permalink)
02 Golf TDI Driver
No; If I had to guess I'd say that it doesn't actually pass smog.
Old 02-23-2009, 10:04 AM   #8 (permalink)
blueflame's Avatar
By moving the fuel line to a clear plastic bottle with marked levels, and the iphone GPS you could easily see how much fuel this bad boy guzzles.
I'd bet using a smaller rear sprocket will increase FE.
Check your spark plug after a run to see if you can lean it up with an adjustment or main jet.
I'm used to 80cc 2 strokes that do 80mph so this is a very detuned setup....
Old 02-23-2009, 10:15 AM   #9 (permalink)
02 Golf TDI Driver
That could definitely work.
[QUOTE=blueflame;89119
[/QUOTE]
Probably, but at the speeds my dad will use it at, probably not much, he's entirely content at 10 mph.
Unfortunately the frame gets in the way of plug removal and the motor has to come loose, then adjust chain . .. .. But definitely a good idea
Do those have transmissions?
I actually tweaked the mixture screw while running at wot with the iphone out to get top speed up from 19 (out of the box) to 26
Old 02-24-2009, 05:45 AM   #10 (permalink)
blueflame's Avatar
6 speed gearboxs and large expansion chambers.
Avoid ethanol fuels with a 2 stroke! They can suffer badly
Magazine: Green Car Journal cfg83 General Efficiency Discussion 4 03-02-2009 12:14 AM
Why are you Green??? what do you dislike about the green Movement? Vwbeamer Off-Topic Tech 33 02-25-2009 08:12 PM
Honda as a green company - perception overshadowing reality? atomicradish EcoModding Central 11 07-19-2008 05:36 PM
Technique quandary: gliding toward a stale green light - to pulse or not to pulse? MetroMPG Hypermiling / EcoDriver's Ed 11 12-29-2007 02:56 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
