Old 05-20-2009, 03:56 PM   #1 (permalink)
prout - '99 protege 1.6l se
laverte - '99 protege se
O2 sensor
for the begenning I just want to say sorry about my spelling im french from Quebec.recently i had a check engin light on,i borrow my frend scanner and it said i have a problem with my first o2 sensor.So i change it, even the second one disconnect the battery to reset the computer of the car , and i still have the check engine light on.does anyone know what can be the problem, my car is a mazda protege 1999 1.6L
Old 05-20-2009, 04:32 PM   #2 (permalink)
Wonderboy's Avatar
98 Civic - '98 Civic EX
90 day: 42.62 mpg (US)
CRXFi - '88 CRX HF / XFi
90 day: 38.84 mpg (US)
01 Insight - '01 Insight
90 day: 48.58 mpg (US)
Welcome to EM!
Air from the outside could be getting into the exhaust system somehwere - check to see if there are any rust holes anywhere near the O2 sensor in your exhaust manifold/pipe. Also check for loose connections between any of these pipes that would let outside air in. I've had this problem on every car I've owned to date probably because of the salty roads in wintertime. I just end up needing to replace the long central exhaust pipe that extends between the catalytic converter and the muffler.
Old 05-21-2009, 05:17 PM   #3 (permalink)
A 1999 model year might have more than one O2 sensor. Did you replace the wrong one?
You should also check the electrical connections to the sensor(s).
-soD
Old 05-25-2009, 10:05 PM   #4 (permalink)
My car said that the rear O2 sensor was bad. I replaced it. Then it said that the front one was bad. I replaced that. Now it is fine. My point is... some_other_dave is probably correct in his assumption that you have more then one.
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 34 10-10-2011 11:01 PM
My Kingdom for a NOx Sensor cfg83 EcoModding Central 19 08-25-2010 07:55 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 01:39 PM
o2 sensor setting for economy aamir_aijaz DIY / How-to 3 03-15-2009 10:25 PM
Perhaps honda specific: Will a code 41 (o2 sensor heater) tank my mileage? SVOboy Off-Topic Tech 13 08-04-2008 10:35 PM
