Old 07-09-2009, 12:36 PM   #11 (permalink)
Big Blue - '06 Dakota Quad SLT
90 day: 20.36 mpg (US)
Miazda - '96 Miata mx-5
90 day: 44.14 mpg (US)
you guys are great
First, thanks for all of the suggestions--I'll be trying as many as possible(or needed) this weekend. I've been driving the car all week and the lite has been on. Aside from the stumble when the car is almost at operating temp. it has been asymptomatic.
Until today. I started it up and the light didn't come on. I drove about 10 miles, and while driving a steady 40 mph on relatively flat road it came back on
There, once again, were no other symptoms. Does this give anyone a better diagnostic clue? -Ed
Old 07-09-2009, 01:59 PM   #12 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Originally Posted by Southcross View Post
some cars use completely different sensors for the front and back...
It's a 97, I'd think both would be 4 wires narrow band.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 07-11-2009, 01:24 AM   #13 (permalink)
LUVMY02CREW's Avatar
TANK the fifth - '02 S10 Crew Cab 4x4 LS
90 day: 20.13 mpg (US)
Originally Posted by SVOboy View Post
You might have gotten a bad sensor. It happens.
Ditto....mine was setting a code on the drivers side manifold and when I swapped that sensor with the post cat sensor, the code followed the bad sensor and truck started running normal again. Like yours, mine was only a few months old.
Good luck!!
Old 07-11-2009, 01:14 PM   #14 (permalink)
Driving the TurboWeasel
Bosch O2 sensors aren't known for playing nicely with GMs and Hyundais. Could be you need a different brand of oxygen sensor for that Mazda, even though it's not a GM or Hyundai.
2012 Chevrolet Cruze Eco 6MT
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 34 10-10-2011 11:01 PM
My Kingdom for a NOx Sensor cfg83 EcoModding Central 19 08-25-2010 07:55 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 01:39 PM
O2 Sensor problem Need help! Curly1 DIY / How-to 1 05-23-2009 07:50 PM
O2 Sensor Resistor Matt Herring EcoModding Central 11 06-26-2008 05:47 PM
