Old 05-20-2009, 12:41 PM   #371 (permalink)
A partial success! You just coded a new Init and got a blip? Cool. All my changes got nothing so far.
I was thinking that too about the universal products. They work with almost any OBDII car, and yet... here we are with no go.
Perhaps we need an active L line to get the initialization done? The 33290 chip only supports the K line though.
Old 05-20-2009, 12:54 PM   #372 (permalink)
I am quite sure you dont need the L-Line.
Old 05-20-2009, 01:01 PM   #373 (permalink)
well Subaru STI is KWP2000 according to this:
http://www.autoenginuity.com/dloads/...user_guide.pdf
Old 05-20-2009, 02:11 PM   #374 (permalink)
cmags's Avatar
Scoob - '05 Impreza Outback Sport SE
90 day: 25.28 mpg (US)
Hey I've been following the discussion recently, Mart, since you mentioned the STi. Looking at your link it seems that only the STi out of the Subaru line uses the KWP2000 protocol, correct?
I ask because I'm building one of these for my buddy (well, I have built it already) but I couldn't get it to init in my Impreza (non-STi). I was figuring I could use my car as a testbed and then plug into his - from your information it seems I cannot.
I haven't had much time for this project lately, and since it seems I don't have the proper vehicle to test on anyway, I'll be looking forward to reading about your progress. Would you be willing to share your code once you get something working? I'd really appreciate it.
Old 05-20-2009, 02:46 PM   #375 (permalink)
Sure but we will need to edit your source as well:
I dont have my code handy (anyway, I am using 2 serial LCD, a RTC clock (will use the subaru stock clock location) and a SD module as well for logging so the code is not much like the one in the svn tree) but it is something like that:
/* ISO 9141 FAST init */
byte iso_fastinit()
byte b;byte kw1, kw2;
// 1) Wait for 300ms with K line high.
digitalWrite(K_OUT, HIGH);
delay(300);
// 2) Pull K line low for 25 +/- 1 ms
digitalWrite(K_OUT, LOW);
delay(25);
//3) Let K line rise high and wait 25ms
delay(25);
//4) init serial connection to 10400 baud, 8N1, 1=0Volt 0=12Volt, least significant bit first
// switch now to 10400 bauds
Serial.begin(10400);
//5) send package c1 33 f1 81 66 33=dest, f1=our tester id, 81=start comms
iso_write_byte(0xc1);
iso_write_byte(0x33);
iso_write_byte(0xF1);
iso_write_byte(0x81);
iso_write_byte(0x66);
//6) wait for response 83 f1 01 c1 e9 8f ae 01=physical address,
// you can read data byte by byte to validate using iso_read_byte to validate ECU response.
return 0;
Keep it mind that the rest of the code does not work for some reason. If you have a message on your LCD like "127 code(s) blabla", you are at the same step as I am right now.
Old 05-21-2009, 12:25 AM   #376 (permalink)
I tried changing the init code a little for the iso 9141 protocol. Anybody want to test it?
Old 05-21-2009, 09:11 AM   #377 (permalink)
At this point I am willing to try 'anything'! Sure, I'll test it. I don't have the car right now, but tonight or tomorrow I can give it a run through.
Old 05-21-2009, 09:16 AM   #378 (permalink)
I can give a try as well.
Old 05-21-2009, 10:54 AM   #379 (permalink)
SubaruOutback - '95 Legacy Outback
90 day: 21.56 mpg (US)
As soon as my LCD gets here, I'll give it a try. I've got a OBD-II 95 Subaru Legacy.
Old 05-21-2009, 11:03 AM   #380 (permalink)
Modding for Eris
Thalass's Avatar
Stockie - '00 Outback GX
90 day: 21.25 mpg (US)
Wife's Car - '06 Corolla
90 day: 34.11 mpg (US)
Horse - '98 GPX-250
Keep working on the subarus! I was going to buy an MPGuino once the exchange rate got back up to more sensible levels (the price nearly doubled in a month at one point), but if I could just tap into the OBD-II plug in my 2000 Outback I'll do that instead.
Completely stock '99 Outback!
Electric 4WD on the moon! Win!
obd2
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 999 12-14-2011 01:18 PM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 06:35 PM
All New Nissan Models to Feature Fuel Efficiency Gauge MetroMPG General Efficiency Discussion 6 11-18-2008 05:57 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-15-2008 12:04 AM
Will Scan Gauge work on mine? bennelson Instrumentation 9 02-19-2008 11:04 PM
