Old 09-28-2009, 11:01 AM   #511 (permalink)
Neat project guys, thanks for your efforts.
I've created a Wikipedia entry for the project OBDuino - Wikipedia, the free encyclopedia.
The Following User Says Thank You to hbachus For This Useful Post:
Magister (09-28-2009)
Old 09-28-2009, 11:33 AM   #512 (permalink)
OBDuino coder
Magister's Avatar
Titine - '07 Elantra GL
Thanks, I was not expecting something like this!
Old 09-30-2009, 07:55 AM   #513 (permalink)
If you wanted to cater for a different user-group, you could easily add a Racing Performance screen with these metrics:
- 0 to 60 timer
- 1/4 and 1/8 Mile timers
- Real time “Boost” (Intake Manifold Pressure)
(see http://www.circuitcellar.com/microch...4_Abstract.pdf for a dsPIC & ELM327 based Racing Performance design)
Of course, we wouldn't recommend these being used on public roads!
Old 09-30-2009, 08:00 AM   #514 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
lol, or anywhere else From an eco perspective I think someone needs to do a CDA calculator, as well as an attempt at a "most efficient" acceleration monitor.
Old 09-30-2009, 09:51 AM   #515 (permalink)
OBDuino coder
Magister's Avatar
- 0 to 60 timer
There is one in my version but it's "hidden"
Old 09-30-2009, 11:47 AM   #516 (permalink)
lol, I thought that might get a reaction on this site.
While I wouldn't be testing such a racing screen, I think there are benefits from making the device appeal to as wide an audience as possible without compromising the basic purpose.
But I would be fascinated to try out your "most efficient acceleration" mode, and I'd rate that highly as feature candy.
For flat ground and a specific vehicle, the most efficient acceleration should be a function of velocity that is fairly constant over other conditions. Once determined, you could compare current acceleration with optimal.
CdA = Cd (Drag coefficient Drag coefficient - Wikipedia, the free encyclopedia) * A (cross-sectional area)
= 2 * drag force / air density * velocity ^2
Ignoring drive train friction and variation in air density (varies with humidity, temperature and altitude), your main challenge will be determining the engine force on the vehicle. There are some simple OBD-based calculations out there that make bold assumptions to derive HP, but I suspect those assumptions are too coarse to support a CdA calculation.
Old 05-11-2010, 10:38 AM   #517 (permalink)
Hi there!
found this obduino thing going and tought... I have a bluetooth OBD scanner with ELM327 chip. loking around shematics I connected ELM's 18 and 17 pins to Arduino Tx and Rx, but all I get is ISO9141 Init..... Failed.
i have not put it in car, just bench testing, could it be that it fails to connect because it is not connected to car? (Yes, I added +12v to OBD reader)
or it is not enough to just connect tx and rx?
I cannot add pictures
thanks
Old 06-04-2010, 06:22 PM   #518 (permalink)
Why does it requires to have a 2n3906 for the brigthness but not for the constrast (direct from the Arduino pin)?
Old 06-04-2010, 09:17 PM   #519 (permalink)
OBDuino coder
Magister's Avatar
This kind of LCD LED can take more than 100mA for brightness so it can not be driven directly by a pin. However the contrast draws almost nothing.
Old 06-05-2010, 04:34 PM   #520 (permalink)
Source code is missing serialWrite and serialRead function that are used in `iso_write_byte(unsigned char)' and in `iso_read_byte()'.
Is that normal?
obd2
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 999 12-14-2011 01:18 PM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 06:35 PM
All New Nissan Models to Feature Fuel Efficiency Gauge MetroMPG General Efficiency Discussion 6 11-18-2008 05:57 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-15-2008 12:04 AM
Will Scan Gauge work on mine? bennelson Instrumentation 9 02-19-2008 11:04 PM
