Old 12-24-2013, 12:09 PM   #1 (permalink)
OBDIIC&C Gauge Insight G1 & Civic HCH1 Only
I now have some OBDIIC&C stock built up.
OBDIIC&C is a niche market device designed specifically for the generation 1 Honda Insight and HCH1 Honda Civic Hybrid. It provides all the stock IMA data along with a host of specific ecm/tcm parameters and enables you to manipulate the soc.
I have twelve built and tested units, minus the case. $249 inc postage.
I have ten kits inc, programmed pic, cable, plug, lcd, components etc etc (Everything minus the case). $149 inc postage.
I have a plentiful stock of plain pcb's. $49 inc postage.
All include lifetime software license and free updates. Hardware is rtb 3 year warranty.
Various case options are available on the insight central forum, as are the free 3d printer files.
I may have a stock of 3d printed cases in the new year, details to follow.
OBDIIC&C Gauge - Insight Central: Honda Insight Forum
All ready to go. Treat yourself for christmas.
The Following User Says Thank You to retepsnikrep For This Useful Post:
Cobb (12-24-2013)
Old 12-24-2013, 09:25 PM   #2 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
I would like to get a kit in the coming months, after I recover from buying my Insight and doing a few needed repairs. All the soldering is through-hole, correct?
Camry Thread
E-Bike Thread
Old 12-24-2013, 10:34 PM   #3 (permalink)
All my kits and pcb's are through-hole.
Old 10-05-2016, 11:57 AM   #4 (permalink)
Obdiic&c owners manual..
Finally got round to writing one.
New firmware update to accompany manual.
Obdiic&c V08 firmware
Old 12-19-2017, 06:34 AM   #5 (permalink)
OBDIIC&C Code and Manual Update
It's taken many long days of coding work to produce this new version and the updated pdf manual. Please got to Insight central to download the new versions.
Lots I haven't tested. Have a look round.. The menu system is very different.
The top menu line is the active item.
So scroll Up/Down to get what you want onto the top line.
To exit the menu (at the moment) you have to be back to the first line with Menu at the top.
Then Press to exit.
Once you have your chosen item on the top line.
Right allows you to change that parameter value.
Left activates that function if it's a function.
Press restores the previous value back into the item shown.
So if you fiddle with a value and mess it up just Press to restore it.
For US cars you must use the Menu 'Car Type Flag' to select
UK1 1999-2004 = $01
US1 1999-2004 = $02
US2 2005-2006 = $04
Or the gauge won't work correctly.
Then you need to change the parameters for the appropriate defaults in the normal way.
There are now 16 default parameters for each type.
The sleeker code should make it easier for me to add the other DTC error database modules.
I saved about 5k bytes out of 50k in the rewrite...
I still have 13k space left in the pic18F2620 memory..
Bug and test feedback reports are vital to development.
Have a good xmas..
