Old 07-28-2009, 01:42 AM   #1 (permalink)
Yaris - '07 Yaris Liftback
Octane
All a higher octane rating does is cause the fuel to burn more slowly. Sure, this can help one to advance or retard the timing, but octane alone offers no benefits whatsoever by itself, except a lighter wallet.
Old 07-28-2009, 01:44 AM   #2 (permalink)
saturn - '99 sc1
90 day: 35.67 mpg (US)
thanks
Old 07-28-2009, 01:48 AM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Yes...In general one should not put things in their car their car was not designed to burn.
Old 07-28-2009, 03:30 PM   #4 (permalink)
HX1 - '98 Civic HX
90 day: 48.08 mpg (US)
But higher octane has a useful purpose.
Old 07-28-2009, 04:09 PM   #5 (permalink)
Its only purpose is to deal with timing changes, and yes, that is useful to some I agree.
Old 07-28-2009, 04:18 PM   #6 (permalink)
HX1 - '98 Civic HX
It is not that simple. Higher octane allows higher compression which in turn allows more power per unit of fuel to do work and not get wasted out the exhaust or as heat into the engine cooling system. So an engine built with low compression cannot really make use of high octane fuel like you say. However, an engine with high compression can use high octane fuel more efficiently and produce more useable power per unit of fuel. Higher octane has a purpose. Slow burning fuels allow more power to be useable and not wasted in a piston engine. Quick burning fuels (low octane) lead to more wasteful piston engines. It is more of an engine design question than what fuel to put in your tank.
Old 07-28-2009, 04:26 PM   #7 (permalink)
Well, I can agree with that. I guess what bugs me is people who drive cars designed for 87 who think that 93 will "give them more power." No, it won't.
Old 07-28-2009, 05:27 PM   #8 (permalink)
HX1 - '98 Civic HX
Yeah, that bugs me too. The only possible way they would get more power is if the computer has been pulling timing because of knock with low octane and then they put in higher octane and the timing is allowed to advance by the computer. I doubt that happens very often.
Old 07-28-2009, 06:16 PM   #9 (permalink)
chuckm's Avatar
Exploder - '02 Explorer xlt
Rolla - '02 Corolla ce
90 day: 44.43 mpg (US)
The volumetric fuel value (in btu/gal) is almost identical from grade to grade (not accounting for differences in ethanol additions). For many years, I had thought that premium had a slightly lower volumetric fuel value, but the difference is maybe 1%.
"Jesus didn't bring 'Natty Lite' to the party. He brought the good stuff."
Old 07-28-2009, 07:26 PM   #10 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
Actually, modern cars have knock sensors that automatically retard the ignition if you are running a gasoline with low enough octane to knock. The more retarded the ignition, the less HP and less FE.
The FE effect is not overly dramatic. I'm baselining a 96 Impala SS with a LT-1 Corvette engine. FE drops off about 1.5 MPG on 87 octane vs 94 octane. The power difference is quite noticeable.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Effect of fuel octane number on FE hummingbird EcoModding Central 32 10-28-2009 01:50 AM
87 octane vs 89 octane kill-9 General Efficiency Discussion 42 08-15-2009 06:12 PM
Anybody else, or am I the only one? Dutchdivco Introductions 18 06-18-2009 03:18 PM
87 octane and retarded timing Quattro General Efficiency Discussion 4 02-20-2009 09:29 PM
Ethanol in gasoline i_am_socket EcoModding Central 83 12-18-2008 10:01 PM
