Submit Tools LinkBack (2) Thread Tools
Old 09-29-2009, 06:40 PM   #11 (permalink)
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 35.32 mpg (US)
...most of the "older" full wheel covers had 'springy-clips' all around the cover circumference which "caught/grapped" not the rim lip (where weights commonly attach), but rather the flat surface below the rim lip.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Old 09-29-2009, 08:48 PM   #12 (permalink)
04 Accord - '04 Accord EX
90 day: 34.48 mpg (US)
Originally Posted by winkosmosis View Post
Mercury Cougar.
THUNDERCATS HOOOOOOO
I lol'd
Old 09-30-2009, 06:44 PM   #13 (permalink)
15" Olds
I have two of these 15" I got from a client.I'd recommend them to anyone.They stay put until removed on purpose and are completely "silent" unlike my bang-on Moonies which sound like a plague of locusts .------------ My thoughts on the expensive 16" MOONs,are that they're probably a low sales volume item for now and will command a niche price until volume sales kick in if at all.
Old 09-30-2009, 07:45 PM   #14 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 44.17 mpg (US)
aerohead -
That's what I was thinking.
CarloSW2
What's your EPA MPG? Go
and find out!
Old 09-30-2009, 07:50 PM   #15 (permalink)
Gen II Prianista
Rokeby's Avatar
aerohead,
Of all the covers posted so far, and the 100's I looked at on the 'net, I like
the 15 in. Olds the best. Special thanks to cfg83 for the post.
As a point of interest, do the spring metal tabs that hold the cover on also
have a large diameter wire tensioning ring?
My thoughts on the expensive 16" MOONs, are that they're probably a low
As to the price of the MOON 16 in. racing discs, at ~$50 each, they come in
a lot cheaper than many of the OEM near-aero wheel covers that I have
found. A few typically start at $40, but most are up in the $70-$80 range.
And most times you're looking at single covers, and "used but good" quality
at that. I suspect it is because you are in a market with the classic and
heritage restoration crowd who seem to have buckets o' bucks to spend on
perfectly restoring their first car from their halcyon high school days.
"The older I get, the better I was." Anon
Reviewing this thread makes me feel a little foolish. The OEM near-aero idea
seemed like a way to get an inexpensive, quick, and simple maybe-aero
mod. Things sure have worked out a whole lot differently than I expected.
Old 10-21-2009, 11:37 AM   #16 (permalink)
...found this source of older style "smooth" wheel covers (page 3):
www.so-cal-az.com/uploads/SO-CAL-AZ_Hot-Rod_ebook.pdf
...14" 15" and 16" here:
http://www.autoamenity.com/KartList/RD.htm
The Following User Says Thank You to Old Tele man For This Useful Post:
Rokeby (10-21-2009)
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/oem-near-aero-wheel-covers-10343.html
Posted By For Type Date
aero disc cover | VIRGILIO Ricerca | Web This thread Refback 01-09-2010 05:23 PM
OEM Near-Aero Wheel Covers - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 09-26-2009 08:37 PM
Clear Aero Wheel Covers; MBenz Does It First Rokeby Aerodynamics 31 12-31-2009 04:41 PM
Honda OEM wheel covers RPM Aerodynamics 12 05-09-2009 04:57 PM
Plastic wrap aero wheel covers? SVOboy EcoModding Central 5 03-27-2009 12:24 PM
Cheap-o Smooth Wheel Covers bennelson Aerodynamics 40 03-15-2009 11:55 PM
wheel covers: corugated plastic or taped hubcaps? modmonster Aerodynamics 4 02-08-2009 07:54 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
