Old 07-08-2010, 05:37 PM   #1 (permalink)
Black Thunder - '01 Z71 4X4
90 day: 20.25 mpg (US)
Off the line 0-35~
In reading this forum and others I find that I should start off slowly and increase my speed to what is necessary for conditions to maintain the best FE. After getting my scangage and getting it all setup I find just the opposite to be true according to the readings it puts out.
First, the vehicle is a 2001 Chevy Z71, 4 door, 4x4, Mud Tires ( I use them way too often to be able to swap them out. ), 5.3L V8, 3+1 AT, BLACK (that makes it go faster? . The truck has 125k Miles on it and runs great. I keep the maintainance up on it as best as I can. EPA is 13-16mpg and I have normally averaged about 16-17mpg.
When I decided to look into driving habits to improve my fuel mileage I found that the normal recommendation was to start off slow and slowly speed up till I reach the required speed and then to maintain that speed as best I could. After getting and installing the ScanGauge I find that if I stomp the gas from a stoplight (setting the tps @ 50 from 0) which is just below squealing the tires, until i reach 35-40 mph then backing the throttle off till my mph reaches ~ 20-21 and keeping it there till I reach the desired speed (increasing the throttle to keep speed increasing and my mph about what my max will likely be) and I can maintain an average of ~20 mpg over the tank.
Am I doing it wrong? If I do the slow start I drop back to 17 maybe 18 if I am really careful.
Old 07-08-2010, 05:55 PM   #2 (permalink)
Alexa - '07 Civic LX
90 day: 35.92 mpg (US)
FX - '06 FX35
90 day: 17.98 mpg (US)
Priya - '03 Ion 3
90 day: 26.9 mpg (US)
you dont need to "stomp" on it but if you use the LOD setting. You should be in around the 70-80 mark for acceleration.
im sure someone with more knowledge can clarify
Old 07-08-2010, 06:12 PM   #3 (permalink)
Wolfsburg - '03 Jetta 1.8t
90 day: 28.69 mpg (US)
Hi,
ICE engine are more efficient when operating under a certain load, usually found between 65-85%. Try this for a week: Have the gauge ''LOD'' (Engine Load) on your SG display, and try to maintain this value between 65-85% when accelerating while shifting to the taller gear as soon as possible without bogging the engine (MT right ? oh nevermind, just saw you had an AT).
What would be better, would be if you found a BSFC graph for your specific engine. That graph would show you exactly at what load/rpm you should keep the engine. Beware, these graph are kinda rare, and may not even exist for a specific engine
Anyway, have fun with all those EPA and fuel efficiency related things
Old 07-08-2010, 06:17 PM   #4 (permalink)
Dr. Jerryrigger's Avatar
The Sh*t-Box - '99 Impreza Outback Sport
90 day: 27.81 mpg (US)
Edit: Lokalazeros, you posed wile i was writing this... so yeah, it's now rather redundant...
I have found the same thing (but it took much longer, as I still don't have a scan tool).
look at: Brake Specific Fuel Consumption (BSFC) Maps - EcoModder
Your engine is likely not on this list, but it shows with other engines, that you get more energy out of your fuel by running it a little bit harder (well hard to my standards). So you want to maximize this to get up to speed, and then drive as gently as you can.
Old 07-08-2010, 07:11 PM   #5 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
With the automatic you want to use as much throttle as you can without delaying the upshifts.
regards
Mech
Old 07-08-2010, 08:15 PM   #6 (permalink)
comptiger5000's Avatar
The Beast - '98 Grand Cherokee (ZJ) 5.9 Limited
90 day: 14.58 mpg (US)
In my Jeep, I find I get best mpg around 1/3 throttle on accel, which shifts around 2300 rpm. If I go too much slower, it takes forever to get up to speed, wasting a bunch of gas. Much faster, and it brings the RPMs up too high. By the time I get up to about 2500+ on acceleration, she's really hauling, so the only need for that is merging.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 07-08-2010, 08:54 PM   #7 (permalink)
Ok, thanks all. At least now I don't feel like I have something broken. I think after I get the driving habits fixed I will start working on mods, I think I need to learn the basics first.
I appreciate the help, and will look around for that graph. perhaps I will get lucky.
Old 07-08-2010, 09:06 PM   #8 (permalink)
By the way, has anyone else had problem with the ScanGauge2 causing the Radio clock to not keep time? Mine has just reset to seemingly random time every time I leave it for a few hours or more. Only happened since I have had the scangauge plugged in.
Old 07-09-2010, 11:41 AM   #9 (permalink)
Ok, I set the gauge as you suggested and tested it out. I am now wondering if there is a calibration that I need to do for this part of the gauge as well. I have calibrated the speed, engine size, tps, but even if I floor the silly thing I only bring the LOD to ~40 ( the mpg drops to 1.5-2, tps is 100, tires are squalling ) If not then i suspect I would have to be pulling or carrying a lot of weight to get the engine to preform at 60-80% capacity. It "seems" like the 20% range is where it shifts about right but still accelerates quick enough that the Police look at me and stare a bit... My "normal" acceleration would only pull about 8-10% but then my "normal" driving habits are what I am trying to fix.
Old 07-09-2010, 12:31 PM   #10 (permalink)
YJ - '89 Wrangler
FOCUS - '00 Focus ZTS
The Wife's Hot Rod - '09 G8 GT
Last 3: 23.22 mpg (US)
It never affected my Mitsubishi. I have recently switched it to my 97 Suburban, which I haven't driven for some time. I noticed that I need to reset the clock quite often now. I will unplug it for the ride home & see what happens this weekend. I just figured the bus was 13 years old & doing weird things.
Don
Honda ATF return line? 99LeCouch Off-Topic Tech 3 05-03-2010 11:40 PM
Filling oil just to min line? better mpg? Fr3AkAzOiD EcoModding Central 36 04-17-2010 10:58 AM
Rusty Brake Lines Question 99LeCouch Off-Topic Tech 18 10-13-2009 01:33 PM
the bottom line, people have be forced to conserve. diesel_john General Efficiency Discussion 57 05-17-2008 11:37 PM
Cheap Fix for a Tranny line? WaxyChicken Off-Topic Tech 18 02-14-2008 03:29 AM
