Old 03-01-2009, 04:25 AM   #11 (permalink)
I've been interested in the MPGuino since last year, I've got a 1992 Geo Metro LSi 3 cylinder convertible. I have a few questions:
If your on version 74 now and some later version looks better how do you update? I'm not program or electronic savvy; as a point, this will be the first thing I've soldered in over 20 years and have no idea how to load a program for the MPGuino.
If you want to encase the MPGuino what is a good option for the nontech user?
Can the 4 wires be built into a plug in harness and allow the MPGuino to be plugged in rather than hard wired? This seems like a very doable mod. Any suggestions? - Dale
Old 03-01-2009, 06:54 AM   #12 (permalink)
dcb
Don't Panic
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
randerson, the software is all loaded, v 0.75 is currently being shipped, working on options for tdi/audi at the moment. You can start with the wiki (don't need the assembly instructions). MPGuino - EcoModder , You will need battery power, ground, vss and injector leads, then once installed you can go into the setup screen by pressing left and right buttons simultaneously (briefly) and use left and right buttons to navigate the values and middle button to change the digit at the cursor or select OK or XX (Cancel) in the setup screen while in the vehicle.
dri, if you should need an update for some reason, you can "chip swap" with an existing arduino. If you are really in a bind I can reflash it if you send it (the chip or the unit) back via S.A.S.E, for say, 6 months from receipt.
I would suggect check out the enclosure threads, I don't usually bother, but they can be made out of anything. The plug-in would require custom plugs for every conceivable vehicle, and the plugs would probably cost twice as much as the unit. It does come with a 3.5 floppy style power connector and crimp pins so you can unplug the guino easily once installed.
"I kicked a giant mouse in the butt! Do I have to draw you a diagram?"
Old 03-01-2009, 10:01 AM   #13 (permalink)
02 Golf TDI Driver
The Golf - '02 Golf GLS TDI
Last 3: 57.98 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
If somebody is thinking about this; I say go for it.
II ordered all of my parts, then lost the guino; this way you only have 1 part to loose.
Old 03-01-2009, 04:26 PM   #14 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Posting in the weekly roundup, will have a dedicated blog post up this week to help promote the guino,
Old 03-02-2009, 01:17 AM   #15 (permalink)
Ryland's Avatar
Tomos Arrow - '05 Arrow ST
90 day: 101.68 mpg (US)
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
This is exactly what I have been looking for! I will be making a donation as soon as I make sure the rest of my bills are paid as this device should pay for it's self within a year or two.
As far as plugs go, I would think if someone came up with a plug that would fit the civic, and one for the metro that they could easily sell them, because if you figure out how to make one then make a small batch of them.
Old 03-02-2009, 03:47 AM   #16 (permalink)
Dartmouth 2010
SVOboy's Avatar
The post will go live on the blog tomorrow.
Keep up the good work!
Old 03-13-2009, 02:17 AM   #17 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Taurus GL (Sedan)
90 day: 22.51 mpg (US)
I am kindof confused also. What are the "updates"? Do we have to plug the MPGuino into the computer and download new software when an update is released?
Also, Can I order the pre-assembled one with the blue LCD screen? Or would I have to buy both and switch it out myself?
Old 03-13-2009, 03:17 AM   #18 (permalink)
dcb
Don't Panic
dcb's Avatar
If your mpguino is working, you don't "have" to do anything. The subject of programming gets exponentially complicated from there, but if it isn't working at all and you don't have the facilities to reprogram it, then send it in with return shipping for reprogramming, for 6 months.
This is the bare bones mpg gauge, meant to be tossed onto the dashboard and used, not designed for development/programming/updating but the chip is socketed so it is not hard to reprogram it:
Open source PCB design
re: blue LCD, tried them, lots of glare, harsh at night. The yellow green ones have the best visibility under the most conditions after trying lots of LCDs and doing lots of testing with this model, so that is what I ship. Not enough unit volume here to get into a lot of hardware options here (each option requires testing too imho), but I can leave the LCD unsoldered if you really want to use one of your own choosing. Just make sure to communicate that.
P.S. this uses a standard 3.5 floppy power connector if you are looking to put plugs in multiple vehicles and have an old power supply handy.
Old 03-13-2009, 11:17 AM   #19 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
So does the prebuilt model still show all the different readouts the kit does? Or does it only show tank mpg?
Old 03-13-2009, 11:19 AM   #20 (permalink)
Moderator
Daox's Paseo - '97 Paseo
90 day: 67.16 mpg (US)
Daox's Prius - '04 Prius
90 day: 52.66 mpg (US)
I ordered mine a week ago or so. It came a day or two later. Can't wait to install it! Accurate MPG with EOC, priceless!!!
EcoRenovator.org - Efficient living and green home improvement
Prius Build Thread
Paseo Build Thread
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 894 10-22-2009 10:07 PM
MPGuino installation/setup: 1998 Geo Metro (Pontiac Firefly) MetroMPG OpenGauge / MPGuino FE computer 12 10-11-2009 04:29 PM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 06:35 PM
MPGuino makes Make MetroMPG OpenGauge / MPGuino FE computer 2 01-06-2009 01:22 PM
Modding the MPGuino ac7ss OpenGauge / MPGuino FE computer 5 11-18-2008 04:40 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
