Old 03-13-2009, 11:36 AM   #21 (permalink)
If the preassembled unit needs to be reprogrammed does the chip need to be removed from the unit?
How is the chip or unit connected to the computer for reprogramming?
Old 03-23-2009, 10:28 PM   #22 (permalink)
04 Accord - '04 Accord EX
90 day: 34.48 mpg (US)
It is possible to ask for a "custom" kit?
I would want one with no LCD (and maybe reduced donation) as well as front mount buttons instead of top
Old 04-08-2009, 06:43 PM   #23 (permalink)
metromodder
metrognome - '94 metro
$ sent
Old 04-10-2009, 09:07 PM   #24 (permalink)
metromodder
Where do they ship from? Ordered 4/8, and can't wait to play!
Old 04-10-2009, 10:10 PM   #25 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Tracking number says it left chicago on 4/9, will probably be there tomorrow
Old 04-11-2009, 03:12 PM   #26 (permalink)
Donation sent, I can't wait to start working on my F150! It has two gas tanks for a reason.
Old 04-11-2009, 06:53 PM   #27 (permalink)
metromodder
Got it today! Wiki shows resistors at inj and vss connection. do i need these, or are they eliminated or incorporated within the assembly? Also, which wire at each? My 94 Metro has 1 green + 1 purple at vss, and 1 tan + 1 tan w/black at inj. Try and see? or will wrong wire cause damage? And I'm using telephone wire. Heavy enough? Sorry for so many ?'s. I want this hooked up NOW!!!
Thanx again
Old 04-11-2009, 07:43 PM   #28 (permalink)
dcb
needs more cowbell
dcb's Avatar
The resistors are all built in, just need to tap your wiring. If your 94 is like this 98 then you will have a yellow/green at the ECU behind the glovebox and a yellow/blue at the injector under the air cleaner (for the injector connection), use constant 12v for power.
Maybe this helps:
Metro - EcoModder
Old 04-11-2009, 08:03 PM   #29 (permalink)
metromodder
thanx, I should have it wired shortly. With luck I'll test run it yet 2nite!
Old 04-11-2009, 09:27 PM   #30 (permalink)
metromodder
Got some weird #s, like speed at a standstill. Think maybe pinned wrong side of vss. I'll try flopping it tomoro.
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 999 12-14-2011 01:18 PM
For Sale Preassembled MPGUINO NEW $45. randall OpenGauge / MPGuino FE computer 1 10-24-2009 05:13 PM
MPGuino, Preassembled BRAND NEW Sean T. For Sale 4 10-22-2009 08:00 PM
Brand New MPGuino Preassembled Sean T. For Sale 1 06-17-2009 02:02 AM
