Official MPGuino preassembled now available
http://opengauge.org/mpguino/ Now there is an easy way to support opengauge.org :) Please have a look, and thank you for your support. http://opengauge.org/mpguino/guino1.JPG http://opengauge.org/mpguino/guino2.JPG Dave. |
Awesome!!!
It's too d**m cold here & no garage or I'd order one today.
Any info on which processor, amount of ram, software version, ...??? |
it's your basic atmega168 as planned. I will have version .75 on it with the instant gph fix. The chip is socketed and comes with the bootloader if you like to to chipswap.
I put long stem buttons on it so it should be easy to build a case around it. |
Very nice dcb!
Thanks,
There's plenty in stock. |
Nice, too bad I already bought the other kit formed one with the buttons to the right of the LCD....oh well. now I just need it to warm up here so I can get this puppy installed along with my L1H1 A/F display.
Is v 0.75 an "official" update? Can we get it added to the wiki? I'll do the work of the writeup and edit the wiki if I knew what the changes were from 0.74.
That would be helpful as some of us that have received the older boards still have ver 72 or 73 and need to update.
I made my donation and received my unit 2 days later.
I have questions about setup. I assume that all code/software that is needed is already loaded. Is that correct? So all I need to do is input VSS and injector information, correct? How is that information entered? Do I install in the car first and then once powered up enter the information? Is there instructions somewhere? Thanks. |
