Old 07-30-2008, 07:11 PM   #1 (permalink)
Renaissance Man
Formula413's Avatar
Sleepwalker - '97 Firebird Formula
90 day: 20.04 mpg (US)
Spock - '92 VN750 Vulcan
90 day: 49.39 mpg (US)
03MX - '03 Civic Hybrid
90 day: 49.04 mpg (US)
Oil change guys under-inflated my tires
I brought my car in for an oil change last week (yes, I can change my own oil, more on that later) and ever since I had been noticing that my mileage was off about 1.5 mpg. My mileage on my commute to work is fairly consistent, so I noticed it right away. Then I remembered seeing the guy putting air in the tires, so i check the pressure, sure enough, they ranged from 27-30 (sticker calls for 32). Fixed it before I left work today, and the mileage is back. At least I know I'm paying attention.
And yes, I can change my own oil, but. On my Escort the filter is between the block and the firewall and it is nearly impossible to remove without spilling oil, no matter how big a drain pan I use. I live at an apartment building so the only place I have to work on cars is at my parent's house in the driveway. My mom already got po'd at me for spilling oil once, I don't want to lose the use of my "garage". So I hunt around for one of the repair chains running a special for like $20 or so. The oil and filter cost about $11 anyway. I go to a repair place rather than a quick lube so at least a real mechanic is working on the car. I always change my own oil on the Firebird, which is a lot easier to work on.
More choices...
Old 07-30-2008, 08:29 PM   #2 (permalink)
Weight Reduction
ankit's Avatar
4x4 - '06 Altima 2.5 Special Edition
90 day: 29.04 mpg (US)
Mom's Van - '99 Voyager SE
90 day: 25.62 mpg (US)
Send a message via AIM to ankit
It's great taht you caught that so quickly, I don't think I would have unless the ride was uncomfortable.
Wow ford really made it nearly impossible for you eh? I like how my filter is right behind my wheel, don't even have to jack car up or anything.
BTW-I Like your sig.
Most of my trips are made in rush hour traffic to and from school.
Live Simply So Others Can Simply Live
-Ed Begley Jr.
Old 07-30-2008, 09:02 PM   #3 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Formula413 -
Yeah, I have to check my tires after I have my car serviced. Sometimes I ask them to leave the tires alone. When I have my tires rotated, I deflate them to 45 or 40 (rated at 51) to avoid a lecture. Then I pump them back up.
CarloSW2
American Solar Energy Society
Old 07-30-2008, 09:47 PM   #4 (permalink)
Boy Blue - '93 Cherokee Country
90 day: 18.55 mpg (US)
I had my tires inflated about 40-41 until a recent oil change, and looking at the receipt noticed my tires were deflated to 30 psi. There was a noticeable difference in the driving by means of surface drag I could pick up on (eg - rapid decelerating when doing pulse and glide).
Curious question though, what is max inflation tire rating many of you have on your tires? For me it is 44 psi max, and I try to stay around 41.
Jeep: 25+ mpg or bust
Old 07-30-2008, 10:16 PM   #5 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
I do oil changes daily at my shop. I always put what the car manufacturer recommends which is noted on the door sticker. I always thought that I could help people save fuel by pumping them up to max, but it is my duty to make sure I performed my job correctly. Most of the oil changes that are not regulars have under-inflated tires 99% of the time anyway.
Old 07-31-2008, 12:49 PM   #6 (permalink)
Happy Hyper
Jake's 05 Malibu - '05 Malibu
90 day: 31.42 mpg (US)
Send a message via Yahoo to jakemacd
oil changed yesterday
Yeah! I just got my oil changed yesterday. I've just recently pumped my 44 psi max tires up to 41 psi (and I'm hoping someone more knowledgeable can tell DotorP82 and me if this is good or can we go more). I was just glancing at the invoice telling me all of the things they "checked". There it was, right down near the bottom in black and white, both front and back tires measured at 30 psi. Hmmmm. The guy didn't mention anything to me when he handed me the keys expect for "...everything looks good and I reset your oil change gauge for you." ( I hope he wasn't looking for a tip.) With my little 12v pump it took a lot of time to pack another 10 psi into those babies so now I'm hoping he cut some corners. Whew! As it turns out, they were all still sitting at the 41 psi. I'm ready to go higher if that is generally understood to be better and still safe. Anybody?
Old 07-31-2008, 01:16 PM   #7 (permalink)
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
I HATE handing my keys to a mechanic. It has only ever happened once for a timing belt change. Now my car ticks and the valve cover is missing a screw.... wait, i just put 2 and 2 together... i hope there isn't a screw in my valvetrain...
A friend of mine is a mechanic. Her brother was changing his brake pads in the driveway and asked "what do I have to torque my tires to?" she said "Just put them all to 115" and looked me and said "he is so dumb when it comes to cars". I said "115 seems a little high, mine are only 85 spec"... "yeah, we just put them all to 115 at the shop."
Never trust mechanics because they are certified. Trust them when you know they do a good job. She'll never be putting my tires on my car.
Old 07-31-2008, 01:35 PM   #8 (permalink)
Happy Hyper
lug nut torque
So that's why everytime I have to remove a wheel after I've had my tires rotated in a shop I've got to break out my steel pipe tire iron extender!
Old 07-31-2008, 01:38 PM   #9 (permalink)
Often they just hammer on them for a while with the impact gun. "That'll hold em on there good"... yeah, and strip my studs, too.
Old 07-31-2008, 01:39 PM   #10 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
When I got new tires recently, they inflated them all to ~30 psi. Car's tag says 32, tire's max is 51. I suppose it's an insurance thing where if anything blew out they could sue the garage for "unsafe over-inflation of tires." Mine are at 40 now, but I'll probably take them up to 45 soon.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 09:13 AM
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 04:04 AM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Larger oil filter for better FE? Gregte DIY / How-to 44 05-22-2010 11:12 PM
3000 mile oil change is a myth! SVOboy Off-Topic Tech 15 02-14-2008 03:43 AM
