Old 10-10-2008, 12:21 PM   #1 (permalink)
jeepin xj (pro jeep ecomodder/hypermiler) - '95 CHEROKEE XJ
Last 3: 21.58 mpg (US)
Oil coolers better or worse for FE, was thinking of installing on Jeep
Dont have an oil cooler now just thought for better FE, honestly i dont have a clue how hot the oil is now.
I do have a tranny cooler now to keep that running cool its just your basic auto with overdrive.
i do run amsoil low viscosity in everything front to back top to bottom.
Ive read that oil needs to run certain temp or you will loose fe, just curious on your thoughts
95 jeep cherokee 4.0 auto
Old 10-10-2008, 12:31 PM   #2 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi,
I can't think how cooler oil would affect FE? The cooler itself will add some aero drag, however.
Old 10-10-2008, 12:35 PM   #3 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
I haven't ever seen anything about an optimum oil temp for economy. Other than losses from non-synth oil, which can be more viscous at a cold start.
And Neil has a valid point about increasing aero losses by adding a cooler. That airflow could otherwise be directed around the vehicle instead of throught the rad, engine compartment & underneath.
Old 10-10-2008, 12:35 PM   #4 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Not worth it. The engine was designed to run at the temperature it does. The oil is capable of handling those temperatures. Cooling the oil will essentially make it 'thicker' and thus increase losses from having to pump a thicker oil.
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 04:04 AM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Larger oil filter for better FE? Gregte DIY / How-to 44 05-22-2010 11:12 PM
thinking about going back to making biodiesel: is there competition over oil yet? modmonster EcoModding Central 2 08-30-2008 09:56 AM
mpg + jeep - thinking cap help? tkmd EcoModding Central 6 04-28-2008 09:15 PM
