Old 04-04-2010, 04:55 PM   #1 (permalink)
Engineering first
bwilson4web's Avatar
03 Prius - '03 Prius
90 day: 52.67 mpg (US)
10 Prius - '010 Prius III
90 day: 53.31 mpg (US)
Oil Handbook - good read
Hi,
Almost since I bought our 2003 Prius, I have been fascinated by Prius transaxle oil. The NHW11 model used Type T-IV but the subsequent models used Type WS. I soon learned that changing the transmission oil significantly reduced cold temperature mechanical drag but I also learned Amsoil ATF was not the right answer. Currently, I'm using Type WS because as Type T-IV wears, its viscosity approaches that of Type WS. But I just finished reading a handbook that explains what has been going on:
The Practical Handbook of Machinery Lubrication, 3d Edition, Llyod O. (Tex) Leugner, Noria Publishing, 1328 East 43rd Court, Tulsa, OK 74105, $70+shipping
Tex provides a combination of theory and practical knowledge about lubrication without the sales malarkey found at different lubrication company web sites. Early on, he describes the three forms of lubrication: (1) boundary layer; (2) hydrodynamic, and; (3) elastohydrodynamic. Boundary layer is the typical lubrication film between the surface imperfections. But Tex goes on to discuss in depth the various solid coatings such a molybdenum, boron nitride and teflon. For example, suspended in the oil they are nearly useless but applied as a surface treatment before assembly, they can provide valuable protection during start-up.
Hydrodynamic refers to how as the velocity differences between moving parts increase, the oil creates high pressures to keep the parts from rubbing. The oil literally suspends the moving parts. But Tex also discusses the start-up wear that happens until the parts actually reach operating speed and mitigation systems such as oil pressure before load. This is how our Prius engines start with extended spin-up before the engine begins feeding fuel.
Elastohydrodynamic is new to me but at high pressures and speeds, the oil behaves as a solid, nearly perfect separator of moving parts. The oil viscosity changes but becomes a very efficient, very low friction surface insulating the two parts. For years, I'd noticed that as NHW11 speeds approached 65 mph, the vehicle efficiency improved even more than engine efficiency would dictate ... a 'sweet spot' at 65 mph. It may be we are seeing parts of the car operating in this most efficient, low mechanical drag region.
One of the lessons learned about Amsoil ATF is it 'eats yellow metal' and in particular, the copper measurements went rapidly too high. I caught it and switched to Type WS. However, Tex speaks about a copper test, the right answer when looking at any alternative lubricant for the NHW11 transaxle.
The last bit of the puzzle came from Tex explaining how polymers are added to base oil to extend the viscosity and that the base oil does not 'wear out.' However, these viscosity range improving, polymers are subject to 'shear down.' This explains how the Type T-IV approaches Type WS viscosity over time. In fact, Tex points out that oil doesn't wear as much as the additives are exhausted and it gets loaded with wear material. This certainly is consistent with the oil testing results.
At $70, this handbook is a little more expensive than popular books but the knowledge it provides, the insights, makes it well worth it to the curious. It is free from marketing FUD making it a useful guide for any technician or engineer who really wants to understand lubrication.
Bob Wilson
Local record
The Following 3 Users Say Thank You to bwilson4web For This Useful Post:
bgd73 (04-08-2010), Ryland (04-05-2010), vtec-e (04-04-2010)
Old 04-04-2010, 06:16 PM   #2 (permalink)
mwebb's Avatar
1996 geo metro - '96 metro base
bobistheoilguy
there is a lot of lubrication related info located
here
Welcome
this is a little free.
most car owners do not have a clue about the correct oil that their car should be using .
most are using the WRONG oil / lubricants .
the info is here , should anyone be interested in using it.
those that do not wish to learn should be using...
synthetic oil with the specification of ACEA A3,B3-B4
as a bare minimum ,
many cars that are newer than 2004 will need a better grade of oil than
even that.
study and learn , or not .
Old 04-04-2010, 07:12 PM   #3 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
There's as much unsubstantiated opinion floating around at Bob's as there is anywhere.
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
bgd73 (04-08-2010), bwilson4web (04-04-2010)
Old 04-04-2010, 07:54 PM   #4 (permalink)
Engineering first
I had enjoyed Bob's site several years ago but The Practical Handbook of Machinery Lubrication has no 'soft sell' contents and covers the subject matter in more detail. It is a vendor independent, experience based, study and report that looks at lubrication in depth. For example, the introduction:
It seems Canadian industry could be saving itself well over $5 billion annually. How? By paying a little more attention to problems related to friction, lubrication, and wear. . . .
In contrast, Bob's looks pretty much just at engine oil and no real look at industrial lubrication. IMHO, private vehicle operation is a big market but not very conducive to controlled studies that compare A to B to A.
The author, Tex, also excoriates 'penny wise' procurement and management decisions that buy cheap lubricants, extended change intervals, absence of testing only to pay with equipment failures and production losses. At work I'm having to deal with a procurement department that is pulling the same sh*t. When they screw up and order something that doesn't meet the customer requirements ... they try to force engineering to change the requirements to meet what they bought. Only a fool tries to trick Mother Nature. <grumble>
There is more to lubrication than what Bob's covers ... if you're curious.
Bob Wilson
Local record
Old 04-04-2010, 08:08 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Frank -
Arghhhhhh, and I thought they were the bee's knees.
CarloSW2
American Solar Energy Society
Old 04-04-2010, 11:46 PM   #6 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
Sure wish that was true. IMHO the place is full of what I call "recreational oil changers"- boys who actually think they are doing their engines a favor with excessive oil changing, and excessive expenditures on oil and oil related products.
bwilson4web (04-05-2010)
Old 04-05-2010, 01:27 AM   #7 (permalink)
Engineering first
Amen to that brother!
They keep citing brands without a lick of facts and data. Nothing!
Once upon a time there was a web site that was testing different engine oils, not very well, but at least they were performing oil analysis. Yet you could never tell what the heck the ICE usage profile was. . .
Please understand I'm more interested in transmissions and differentials (where they exist) than engines. What a joke ... Fool and money, soon parted.
Bob Wilson
Local record
Old 04-08-2010, 02:22 AM   #8 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
I have been there at bobs site. I agree with you.
As if all engines are the same..
what would bob do with a 100psi trochoid oil system with 4 relief valves in an all aluminum liquid cooled boxer engine...
the real answer? anything you want.
the polymer stuff has been a nuisance as well as a blessing, I fall for the latest and greatest all the time. My latest is castrol edge, expensive, and it does not like to stay behind my new cam seal..but..everything else is absolutely fantastic...that is probably not on bobs site either.
Old 04-08-2010, 10:11 AM   #9 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...from what I've "seen & read" the criteria for one oil being "...better..." than another has been (IMHO) either:
(a) technical hype,
(b) marketing hype,
(c) colorful hype, or...
(d) today's 'sale' hype.
...detect a "trend" here?
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970˝ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Transaxle Oil TomEV Fossil Fuel Free 12 12-12-2009 02:49 AM
--- How do $19.99 oil change places do it?! --- basslover911 The Lounge 21 09-12-2009 12:25 AM
Oil Analysis on Prius @ 15k miles, 0W20 Mobil1 krousdb Hybrids 13 07-11-2009 10:46 PM
Good Veggie Oil conversion!?!? bennelson EcoModding Central 12 02-14-2008 10:09 PM
Book report: The Last Oil Shock by David Strahan AndrewJ The Lounge 0 01-16-2008 11:55 PM
