Old 11-20-2009, 09:52 PM   #1 (permalink)
Silver Bullet - '00 Firefly 4 door model
90 day: 12.74 mpg (US)
Oil leak at thermostat housing and cylinder head
Or is it ? Is it even possible for oil to leak through here, or just coolant ? Maybe I am getting a leak from the Camshaft Sensor Housing and the Cylinder head. Expert opinions anyone and suggested fix ?
2000 Firefly 4 dr Automatic
Old 11-24-2009, 05:59 AM   #2 (permalink)
Wanderer
Sorrow Six Star's Avatar
Winona - '86 XT DL
I don't see anything really... there does look to be a tiny coolant leak at the T-Stat gasket but it looks dry... and could just be dirt from before the last gasket change.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Old 11-24-2009, 10:52 AM   #3 (permalink)
It's hard to see because I keep the engine very clean, the camera does not do justice.
Old 11-27-2009, 08:34 PM   #4 (permalink)
BUMP . i want to find out if there is any such oil seal on this side of the sensor housing. i know there is one seal for the timing sprocket but no details are given in the factory service manual of the camshaft sensor housing.
Mullet's Metro Project Johnny Mullet EcoModding Central 284 07-25-2009 12:08 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
