Old 08-25-2009, 04:14 AM   #1 (permalink)
OK to change I/O pins ?
Was there a reason for putting the Injector input on, specifically, Digital 2 & 3? I'm thinking it would make more sense to put them on Dig 15 & 16 (aka Analog 1 & 2), so that all inputs are clustered together, and the top row can be pretty much dedicated to the LCD.
Can anyone foresee any problems with this move, other than me having to mod the source with each rev? Is there an actual, physical difference between the "Digital" and "Analog" input lines?
Aside from that, I'd also like to rearrange a couple LCD wires that criss-cross.
Old 08-25-2009, 09:28 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
2 and 3 are the external interrupt pins, they are special because they can differentiate between a rising signal and a falling signal. So essentially one pin fires a tiny bit of code when the injector opens and one the other one fires a tiny bit of code when it closes.
This eliminates any guesswork in the interrupt.
The LCD wires were chosen because they were convenient for standard arduino layout and left some multi purpose pins open. Will probably change in the prebuilt code someday.
The Following User Says Thank You to dcb For This Useful Post:
nickdigger (08-25-2009)
Old 08-25-2009, 05:44 PM   #3 (permalink)
Thanks for the explanation. Guess i'll just leave well enough alone.
wrt the LCD, were you trying to leave the PWM pins open? That i can understand, but Dig 4,5,6 connect to LCD 4,6,3. D 4,5,6 --> L 3,4,6 looks cleaner ... unless there is another special signalling issue that forced this arrangement.
Old 08-25-2009, 05:49 PM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
one of them got crossed when I realized I could control contrast via pwm, that may be what you are seeing.
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 34 10-10-2011 11:01 PM
Oil change guys under-inflated my tires Formula413 The Lounge 26 06-20-2010 09:46 PM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 03:01 PM
change habits, change car landscaper52 EcoModding Central 3 07-12-2009 09:29 AM
Article: CAFE Change Looks Likely SVOboy General Efficiency Discussion 0 12-05-2007 01:24 PM
