Old 06-20-2009, 01:01 PM   #11 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Escort LX
I always Reset my PCM whenever I do something new to my Jeep. After replacing plugs, or distributor, ect.
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 06-22-2009, 09:32 AM   #12 (permalink)
Mechanical Engineer
The Truck - '02 Ram 1500 SLT Sport
90 day: 17.57 mpg (US)
The Van 2 - '06 Odyssey EX
90 day: 18.48 mpg (US)
I would lean toward the valve adjustment, providing that there was too much valve lash and they made the necessary adjustments to reduce lash.
I know from testing with other Honda engines (20hp air-cooled v-twins) that they run very differently in response to valve lash. An engine with more lash reduces effective valve lift and valve overlap. Engines with lower lift and overlap operate more efficiently at low engine speed and will idle at a higher speed for a given throttle opening. Reducing lash will reduce idle without adjusting the throttle opening and will move the more efficient power band up the RPM range. For someone who drives for fuel efficiency this is counterproductive.
Old 06-23-2009, 07:53 AM   #13 (permalink)
that sounds about right. I guess it's ok to have a car that is in tip top shape that loses a couple mpg. I also did notice a little more power.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 979 12-26-2011 10:37 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 11:19 PM
Electric Car Wind Generator Charger demo unit bennelson Fossil Fuel Free 12 04-28-2009 12:20 PM
Aero suggestions for my car atomicradish Aerodynamics 17 07-27-2008 03:29 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 10:37 PM
