Old 09-25-2008, 10:25 PM   #1 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Metro Xfi
90 day: 51.06 mpg (US)
OK? XX? Difference
Is there any difference between OK and XX in setup. My guess is OK is save current, XX skip.
Old 09-25-2008, 10:50 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Basically.
If you select "OK", it will save that value and go to the next value.
If you hit xx it is the same as "Cancel", except there wasn't enough real estate to print out the word "Cancel", it ignores any changes to that value and goes to the next value. Useful if you "fat finger" something and didn't really mean to change it.
Taller top gear makes a real difference (10%) Multiades EcoModding Central 58 04-21-2010 10:06 PM
Does this make any difference? 123 Aerodynamics 26 01-19-2009 01:38 PM
Cold air VS Warm Air Intakes - what's the difference? deadman1474 EcoModding Central 48 11-15-2008 07:08 AM
Difference in fuel between 3/4 and WOT Noel General Efficiency Discussion 6 08-06-2008 03:03 PM
The Honda - What a difference spitfire9703 EcoModding Central 10 06-05-2008 12:37 AM
