Old 10-11-2009, 03:56 AM   #11 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
I don't see any underwear or porn so you're OK.
Quite counter-intuitive to my thinking, I would say.
I'd prefer to see porn than, say, that Skechers box. Just sayin'.
As far as the parts, heat the section up with a heat gun or something, then put a flat weight (book with a weight on it) on the part you want. It'll help flatten it out. It may take more than one time, though, to get it flat completely.
Upside, if you flatten it out before cutting, you can get larger sections to work with, which will allow you to trim them up perfectly rather than cutting and hoping.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 10-11-2009, 04:01 AM   #12 (permalink)
My Goal: 35 MPG All City
RandomFact314's Avatar
The Neon - '00 Neon
90 day: 25.38 mpg (US)
G/F's Car - Kyan - '01 Rio
90 day: 23.94 mpg (US)
The Accord - '97 Accord LX
90 day: 22.41 mpg (US)
Lizzy (all city) - '88 CRX Si
House of Tudor
90 day: 31.92 mpg (US)
yeah and I was thinking about heating it up to a good temperature, flattening it with a piece of glass and some weights on top and then maybe sanding it down a little to make it a little smoother.
After that I will probably drill some small as possible holes to fit the zip ties through it unless I can get a good way of putting it on there using the screws that the other grill piece is screwed on with, in that case I will take the grill piece off and screw the new grill block in or something if its stable enough
Old 10-11-2009, 04:07 AM   #13 (permalink)
If it's not stiff enough to be self-supportive, you can "glue" pieces to it (if it's ABS) by soaking bits of it in acetone for a few mins. They'll turn spongy and gooey, and as the acetone dries, the plastic hardens back up. It only works with ABS, though, that I know of.
Good temp = 200* I think. You don't want to go much higher than that, but you want it pliable enough to lose it's elasticity (memory), so that as it cools, it will "remember" the new shape, without being stressed into form.
A good, thick reference book with about 20# on the back of it should be sufficient to weight it down. Do a few heat/cool cycles to get the stress all the way out of the plastic, and you should be golden.
Old 10-11-2009, 04:13 AM   #14 (permalink)
The Neon - '00 Neon
House of Tudor
Yeah I cant wait to go to my girl friends house and get this going (believe it or not she has a drimmel tool and I don't... ) but I will go over there and start to shape it the best I can with that and then I will look at how the grill piece I have in now is bolted in and go from there on design. I think this will turn out really cool and not too un-natural looking.
I DO have a question though... should I just make it a flat piece or should I kind of point it like the bumper and hood are anyways? I will put up pics asap to make it easier to understand what I mean
Old 10-11-2009, 04:14 AM   #15 (permalink)
Aesthetics are your choice, the difference in aero will be smaller than any test you can afford will register.
Old 10-11-2009, 04:20 AM   #16 (permalink)
The Neon - '00 Neon
House of Tudor
Old 10-11-2009, 04:23 AM   #17 (permalink)
The Neon - '00 Neon
House of Tudor
Well I was going off of a picture like this one, if it didnt count then he (the white car) could have made the glass just flat and used that but he made it curve into the bumper, I know that it is a way bigger block but you understand where I am coming from...
Old 10-11-2009, 11:31 AM   #18 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I haven't read every post here, but It looks as if you want to cut up a spare bumper shroud to make a grille block with.
( Did I get that right ? )
Why not just keep that thing as is and use it as a spare in case you ever need it ?
Just use some pieces of junk plastic or coroplast instead.
Old 10-11-2009, 12:44 PM   #19 (permalink)
It's a lip from another car, not a bumper.
RandomFact - You're looking at filling a much smaller area than the white car was. Much smaller. You have to decide if it's worth the extra work to you to lower your Cd by less than .01.
Old 10-12-2009, 12:13 AM   #20 (permalink)
pstrbrc's Avatar
Wink
No, don't go there, the molecular alignments in the structure are all wrong and will lead to heartache and dismay. and worse fe.
Doncha hate it when someone misses how brilliantly FUNNY you are?????
air dam, air dams, foam core, grill block, grille block
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 01:31 AM
grill "shield" rather than block? lunarhighway Aerodynamics 70 12-17-2010 04:50 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 07:00 PM
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 22 04-07-2009 10:30 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 07:54 PM
