Old 07-07-2008, 07:52 PM   #11 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Id rather change 20 sets of brakes than one transmission. I always use the brakes to slow me down. Except for mountains and a handful of extremely steep low speed hills.
Thats pretty cool they taught P&G in the military.
Winter daily driver, parked most days right now
Summer daily driver
Old 07-08-2008, 03:36 PM   #12 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Vibe base
90 day: 38.88 mpg (US)
Dragonova;
By 'rpm matching' do you mean double clutching?
-Terry
My Pet Threads:
Vibe Mods and What's in a UserName? and YKYAEI
Old 07-08-2008, 07:59 PM   #13 (permalink)
othergames's Avatar
New Blue - '08 Civic EX Sedan
90 day: 36.68 mpg (US)
Originally Posted by OneBadBird View Post
I'm not getting this...how are the brakes being worn out more? Are you actually saving SO much gas that you think the car is a perpetual motion machine that must be held back from its neverending gogogo?
This is engine braking. As you coast down a hill in gear, the engine absorbs some of the kinetic energy in the form of resistance. The wheels' energy is being transmitted back through the transmission to the engine, and is in effect governing the engine's RPM. This is why you speed up going downhill when you disengage the transmission. If you don't distribute any of this kinetic energy to the engine, it must be absorbed by the brakes, by rolling resistance at the bottom of the hill, or ... by damage from an impact.
It's ALWAYS more cost effective to change brakes instead of clutches or transmissions; the only exception was mentioned above: so much braking that braking will reduce the brakes' abilities to stop the car because they're overheating.
Old 07-08-2008, 08:26 PM   #14 (permalink)
Taurus SEX - '01 Taurus SEX
Brakes need to be used. I rarely use my brakes. Last year I had to replace rotors, calipers and pads in the front because they rusted up ... from not being used enough.
When I'm going down a long hill in my taurus, I'll leave it in OD. If I start to slow down, I'll tap the gas for 1-2 seconds. Just long enough to bump my speed back up, but quick enough to avoid the torque converter locking up.
I will be renting a prius and need an ABC tutorial on pulse and glide dsq EcoModding Central 8 06-07-2010 06:50 PM
Pulse and Glide questions..Totally new to this Undie Hypermiling / EcoDriver's Ed 19 08-14-2009 08:26 PM
Pulse and Glide Fuel Economy Calculator 4 valve / Cylinder newtonsfirstlaw DIY / How-to 25 11-04-2008 04:32 PM
Pulse and Glide with hills Tango Charlie Hypermiling / EcoDriver's Ed 14 06-05-2008 02:46 PM
Re-attempting Pulse and Glide (with an automatic) Lazarus Hypermiling / EcoDriver's Ed 6 12-11-2007 09:06 PM
