Old 05-27-2010, 11:47 PM   #1 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
one fast hybrid
I do not admire hybrids..espicially if they do not have an ICE with natural balance (any engine that can run exactly balanced with a benz crank is a "natural balanced" engine)
flat four
flat six
90 degree v8
60 degree v12
are some examples that can run with benz crank perfectly, no errors.
anyho... found this porsche gt3 race car, makes use of a gyroscopic type function, the flat six will never eat it (any inline engine would kill the "gyro"). This concept with porsche goes back to ferdinand days (it is actually an old idea)
Loved to see this.
here is a video:
Porsche Intelligent Performance - 911 GT3 R Hybrid
here is the very informative website:
http://www.porsche.com/usa/aboutpors...ternational-de
Old 05-28-2010, 12:09 AM   #2 (permalink)
Originally Posted by bgd73 View Post
...any inline engine would kill the "gyro"...
Why on earth would you think that? The "gyro" is actually a high-speed flywheel that takes the place of the battery in a conventional hybrid. It's not even connected to the IC engine (execpt through the track), but to the electric motor/generators driving the front wheels.
The advantage of the flywheel for electrical storage is that it's not rate-limited, which allows much higher currents than an equivalent battery pack could deliver, and thus much more assist/braking power. This of course is a definite plus for racing applications.
Old 05-28-2010, 08:57 AM   #3 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
Animated Engines, Gnome Rotary
Here is an engine that is a flywheel.
Just create a means of eliminating the stroke position offset relative to the spinning engine block and you have an engine that transforms itself into a flywheel, capable of storing energy for short bursts of power.
Filed a patent application for that in April 2004.
regards
Mech
Old 05-28-2010, 09:00 AM   #4 (permalink)
You could also put magnets on the perimeter and make it an engine (ic), electric motor, as well as a capacitive energy storage.
All in the same unit.
Drawings of that made August 3rd 2003.
regards
Mech
Old 05-28-2010, 12:15 PM   #5 (permalink)
The problem I see is that the energy would be dissipated by the piston friction in relatively short order. What Porsche is using is probably (I haven't seen details) spinning on magnetic bearings in a vacuum, like this: Flywheel energy storage - Wikipedia, the free encyclopedia
Old 05-28-2010, 10:01 PM   #6 (permalink)
James if you eliminate the stroke by making the journal off set adjustable, then the pistons are not moving in their respective cylinders. They orbit with the cylinders without motion relative to the cylinders themselves. Combine it with a CVT and you can pulse a glide the motor without changing the speed of the vehicle.
that was 2004 thinking.
regards
Mech
Old 05-30-2010, 09:02 PM   #7 (permalink)
Ferrari is working on a similar example. The technology is adapted from the Formula One KERS system. Basically use regenerative braking energy and reintroduce it directly into the transmission.
Malibu Hybrid bennelson Hybrids 17 12-21-2011 10:57 PM
Sat, Sep 19th, Houston Hybrid and Hypermilers Club Dan. Events & Meet-ups 6 09-19-2009 09:02 PM
Are hybrid SUVs a good or bad thing? SVOboy Hybrids 36 04-01-2009 03:48 PM
Milwaukee Hybrid Group Meet 3-28-09 Daox Events & Meet-ups 1 03-28-2009 09:04 PM
Honda Begins Use of Class 8 Hybrid Truck Q1000 Hybrids 0 03-11-2009 07:55 PM
