Old 12-14-2008, 02:28 AM   #21 (permalink)
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
Off topic end.
Thanks. That's about what I get with my Previa 2.4L when warmed up. I would have loved to do those load tests before and after but I only got my mpguino lately.
Old 12-14-2008, 11:02 PM   #22 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Thanks for the input, guys. I imagine this is going to be a work in progress for a while.
I chipped away at the basics a little more this evening: you can now enter weight & A in either Metric or Imperial units. Added a few more explanations & links to the notes as well.
Old 12-19-2008, 01:44 PM   #23 (permalink)
I've made a new page "EcoModder tools". The aero/rr/power/mpg calculator is now linked there as well as a units conversion tool (for mpg --> L/100 km etc.)
You can access it via the "Tools" link in the navigation at the top of every page.
Expect the toolbox to grow & evolve to include more stuff.
Old 12-19-2008, 01:50 PM   #24 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
I likey. Now they just need icons/pics.
Old 12-19-2008, 02:08 PM   #25 (permalink)
Functionality first, then fancyness.
Old 12-19-2008, 08:46 PM   #26 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
If this spreadsheet is valid, I must be doing a bang-up job of improving my aerodynamics and improving engine efficiency by slowing down engine RPM.
Last summer I went to Nashville, TN and back. Slightly cool weather - roughly 70 degrees F. Out and back to same fuel pump so delta y = 0.
I had the full aero treatment: "fastback" bed fairing, air dam, and side skirts.
The trip was entirely an Interstate run and set the cruise on 1700 RPM (70 MPH).
Thev truck weighs 7000 lb. Figure Crr of 0.011 for worn 235-85x16 E-Rated tires pumped up to 100 psi Estimate frontal area at 41 sq. ft. 95% drivetrain efficiency for an overdrive manual. Summer No. 2 diesel.
I got a documented 28.1 MPG over that trip of 600 miles. Playing the variables to duplicate that performance says my Cd is 0.30 and my engine efficiency is 35%.
Am I that good? I figure a open-bed pickup to have a Cd of 0.45 and a diesel engine to have 33% efficency.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 12-19-2008, 10:14 PM   #27 (permalink)
Originally Posted by Concrete View Post
I'm up for anything as long as there is a field for a flat load fudge factor
GPH, like I used is probably not appropriate
watts or Horsepower is probably more acceptable
- what do you think?
Got your PM - haven't forgotten about this.
I'll work it in this weekend, probably as watts to start. (Can always do conversions to other units, if people want.)
Old 12-20-2008, 12:44 AM   #28 (permalink)
Sequential
Concrete's Avatar
The Truck - '00 S10 Extended Cab
90 day: 22.47 mpg (US)
Darin,
Thanks
looking forward to it!
Big Dave,
from what you describe and some of Aeroheads data
I bet you are really doing that well
those are great results & it seems you are in the ball park on your numbers
of course it is hard to argue the particulars without a test facility
but even matching +/- a few percent in each entry is good work
Concrete
Start where you are - Use what you have - Do what you can.
Old 12-20-2008, 10:33 AM   #29 (permalink)
Funny's Avatar
Rolling Lemon - '02 Corolla S
90 day: 40.94 mpg (US)
Perhaps you could also utilize this online tool for gear calculations and adjustments. That is for those of us who are interested in swapping transmissions and gears.
Gear Calculation Tool
I am so excited with all these numbers! God, I am such a nerd!
American by right
Ecomodder by choice
Hypermiler by necessity
Old 12-20-2008, 02:43 PM   #30 (permalink)
GreenMile - '00 Protege ES
90 day: 34.45 mpg (US)
I thought I should point you towards an existing spreadsheet that is the culmination of years of research (I believe it is someones PhD thesis) that is availible on the web.
Just search for Pamvec on google, it should turn up an excel file. It is extremely customizeable for many things that you have already included but also for things like: various drivetrains (hybrids, electric etc), driving models, can specify design goals, or just input known variants. When I used it to model my current car it nailed its MPG rating and I used it to model hypothetical cars.
http://benw385.vox.com/
'Blog' on the open source electric motorcycle project.
Please come visit and comment!
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/online-tool-shows-aerodynamic-drag-rolling-resistance-power-6341.html
Posted By For Type Date
Watts per mile climbing a 6% grade? - Page 3 - DIY Electric Car Forums This thread Refback 01-05-2012 08:49 PM
818 Project Updates From Dave - Page 10 This thread Refback 09-07-2011 12:55 PM
Cfd This thread Refback 08-26-2011 03:29 PM
The Hypermiling/mpg Thread This thread Refback 04-24-2011 11:55 PM
Rad blind experiment - Page 3 - MBClub UK Forums This thread Refback 10-24-2010 02:05 PM
CdA list Daox Aerodynamics 105 01-17-2012 09:48 PM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 10:13 AM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 03:09 PM
Calculating Rolling Resistance SVOboy EcoModding Central 0 11-18-2007 04:20 AM
