Old 03-09-2009, 12:28 AM   #41 (permalink)
Engineering first
bwilson4web's Avatar
03 Prius - '03 Prius
90 day: 52.67 mpg (US)
10 Prius - '010 Prius III
90 day: 53.31 mpg (US)
Actually it works quite nicely for the Toyota and Ford hybrids. The Atkinson cycle and hybrid transmissions provide a relatively flat ICE efficiency. When I put in my NHW11 Prius numbers there was good agreement on:
  • 100 mph mileage - 22 MPG measured and calculated
  • 18 mph maximum range - the model shows ~92 MPG and mine show ~84 MPG
  • 5 mph MPG - the model shows 65 MPG and mine 55 MPG
This is close enough without going nuts but you are right that Otto cycle vehicles need an 'efficiency' curve or table, not a single number.
One of the less well know aspects of hybrids is their ability to keep the engine in an extended, peak BSFC range. There are a two inflection points, the maximum EV speed, 42 mph for Prius, and maximum MG1 rpm that at higher speeds requires the engine to turn faster than idle. But these are subtle effects not well understood outside of the hybrid community. Think of them as shift points and that is close enough.
Bob Wilson
Local record
Old 03-09-2009, 11:03 PM   #42 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Added to the tool: you can now "save" the results of your form input by copying the "Permalink" link at the top of the output table. This'll be useful if you want to post a link so other people can view your entire results.
EG: View the calculations / output for project Sipster (Top Gear USA's 70 mpg @ 60 mph diesel Rabbit being discussed in this thread) from these values:
Vehicle weight: 1043.3 kg / 2300 lbs
Crr: .01
Cd: .42
A: 1.9 m2 / 20 ft2
Fuel energy density (Wh/US gal.): 37953
Engine efficiency: .37 *
Drivetrain efficiency: .95 *
Parasitic overhead (Watts): 400 *
rho: 1.184 kg/m3
* These are flat out guesses on my part.
I still plan to add a link from your garage entry(/entries) so whatever values you have entered for your vehicle(s) will automatically be filled out in the input form when you click your link.
Old 04-09-2009, 05:11 PM   #43 (permalink)
Manic Rabbit
Southcross's Avatar
Slow-n-Low - '81 Rabbit S
90 day: 33.97 mpg (US)
I'm still getting the hang of interpreting the data..... considering engines change efficiency based on operating RPM and Transmission gearing
two thoughts:
1. Ability to put in data for Efficency:RPM:Speed for say 3 (or more) data points?
say:
.15:2500rpm:35mph
.20:3000rpm:40mph
.22:4000rpm:55mph
2. Also... should "Air Density" take into account your altitude, not just temp?
-Edward
Driven on Colorado roads, where NOTHING is flat
Present City 3x / Highway 4x
Goal: 4x / 5x
Old 04-28-2009, 03:01 PM   #44 (permalink)
What engine efficiency % to use for Honda's lean burn VX and HX engines?
Old 06-01-2009, 11:31 AM   #45 (permalink)
Online tool give results really similar to a spreadsheet we have used at automotive engineering for a similar simulation, comparing a truck, a city car and a Formula 1 car.
I will ask to my professors if I can share it ^ ^
Old 06-19-2009, 12:24 AM   #46 (permalink)
MetroMPG, Would you be willing to share the source to the calculator? I'd love to play around with it. Great info and links in this thread guys!
Old 06-23-2009, 10:38 AM   #47 (permalink)
The formula used can be found in this spreadsheet:
http://www.geocities.com/frontsidesk8er/delsolaero.xls
Old 06-23-2009, 11:22 AM   #48 (permalink)
Right I got the spreadsheet. I was hoping for the PHP so I wouldn't have to rewrite it. I'd be happy to share my changes if they're of interest.
Old 02-09-2010, 05:51 PM   #49 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 CJ7
Vehicle weight: 1360.8 kg / 3000 lbs
Crr: .012
Cd: .45
A: 2.6 m2 / 28 ft2
Fuel energy density (Wh/US gal.): 33557
Engine efficiency: .17
Drivetrain efficiency: .90
Parasitic overhead (Watts): 3500
rho: 1.164 kg/m3
Gets me pretty close to what I have observed on an 84 Jeep CJ7
The Following User Says Thank You to TheEnemy For This Useful Post:
MetroMPG (02-11-2010)
Old 02-28-2010, 11:03 PM   #50 (permalink)
civic - '95 Civic DX 3 door hatchback
90 day: 49.27 mpg (US)
SV - '03 SV650 S
90 day: 52.23 mpg (US)
Great tool that can be used for comparison. Maybe the users can try to adjust some values as they see fit to correct the spreadsheet's values to match to their experimental mpg, then use it for comparison.
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/online-tool-shows-aerodynamic-drag-rolling-resistance-power-6341.html
Posted By For Type Date
Watts per mile climbing a 6% grade? - Page 3 - DIY Electric Car Forums This thread Refback 01-05-2012 08:49 PM
818 Project Updates From Dave - Page 10 This thread Refback 09-07-2011 12:55 PM
Cfd This thread Refback 08-26-2011 03:29 PM
The Hypermiling/mpg Thread This thread Refback 04-24-2011 11:55 PM
Rad blind experiment - Page 3 - MBClub UK Forums This thread Refback 10-24-2010 02:05 PM
CdA list Daox Aerodynamics 105 01-17-2012 09:48 PM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 10:13 AM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 03:09 PM
Calculating Rolling Resistance SVOboy EcoModding Central 0 11-18-2007 04:20 AM
