Old 06-02-2015, 04:58 PM   #1 (permalink)
500A Controller troubleshooting
Hi all,
I hope someone can help.
I built my Cougar controller several years ago when I thought my car was closer to being ready. Boy was I wrong!!
It is finally in the car and it looks like it should work but I get no response from the throttle. I did some troubleshooting but getting nowhere.
LED's are on solid, I can watch with a multi meter as the capacitors go through the pre-charge. That takes less than 3 seconds. The contactor signal never happens so I wired a switch to close the contactor.
No throttle response.
So now I load RTD Explorer on my laptop that doesn't have an RS232 port. Got myself a USB serial adapter. So now I have no communication. Don't know if it is because the controller is now talking or the adapter is having configuration issues.
Short of finding someone with an old laptop with an RS232 port I would sure appreciate some ideas.
Thanks in advance.
John
Old 06-02-2015, 07:39 PM   #2 (permalink)
apowers's Avatar
Sometimes my USB adapter does not respond. I keep trying a different port till it does. That might not be your problem.
I would not try troubleshooting at pack voltage. Maybe just use a 12 volt battery.
The first thing I would is if there is a short between motor negative and battery negative. That would be bad.
I hope that helps some.
Then maybe see what is working on it.
Alvin
Old 06-02-2015, 08:21 PM   #3 (permalink)
apowers
Thanks for your reply.
I did have it on my bench and testing with two 12 volt batteries. One for supply and one to simulate pack. Have an extra 5K pot and used it for throttle. I can adjust throttle voltage from zero to about 2.2 volts. With a meter across B- and M- I read about point 5 volts. I'll discharge the caps again and check continuity across those two points.
Thanks for the suggestion.
Old 06-02-2015, 08:25 PM   #4 (permalink)
I forgot to add....
I did take the case off and nothing is visibly burnt and no bad smell. I can spin the motor up with a 12v battery.
Old 06-02-2015, 09:19 PM   #5 (permalink)
apowers's Avatar
Yes continuity is what I should have said. Did you spin the motor at 12 volts using the controller? If so then it should be working.
Did you get the RTD working?
I saw on the other forum someone had built some of the controllers for sale. They had said that if the mosfets are shorted on that the contactors would not close. I never knew this. That seems like a good feature.
Alvin
The Following User Says Thank You to apowers For This Useful Post:
Lectrik (06-08-2015)
Old 06-03-2015, 03:47 PM   #6 (permalink)
Hi Alvin,
I Didn't get as much accomplished as I wanted today. I was trying to find an old used laptop.
Stopped in one local computer shop and asked the guy if he had one with an RS232 port on it. His response was "I don't know what that is". Oh boy !
Anyway, I had not tried the controller and motor together with a 12 volt traction pack but I did today. Still no throttle response.
The motor spins with a 12 volt battery connected directly to it.
The good news is I have an open ( not shorted) between B- and M-. I do read 40 meg ohms briefly before it reads open between B+ and M-.
I have it back in the house and will connect it to my desktop again tomorrow and play with com ports again to see if I can get some communication going. Getting ready to head out for the evening.
Thanks for your help.
Old 06-04-2015, 03:19 PM   #7 (permalink)
Progress
Baby steps today!
After playing with com ports in Windows device manager I am able to make a connection. Previously I was using the utility that came with my USB/Serial adapter.
I can type commands in command line (config, restart etc.) but there is no response. Throttle control also has no response.
Tried running boot loader but all was accomplished was tying up the com port and couldn't disconnect.
Old 06-05-2015, 01:03 AM   #8 (permalink)
PaulH
MPaulHolmes's Avatar
How was the microcontroller programmed? Is it an atmega8 or atmega168? Was this a kit from me, or something else?
kits and boards
Old 06-05-2015, 09:05 AM   #9 (permalink)
The processor is an atmega168. I did not do any programinig to it. I got the kit from you. I just assumed it was pre-programmed
Sent you a PM
Old 06-05-2015, 03:30 PM   #10 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
The serial port should be 19,200 baud, no parity, 8 data bits, 1 stop bit. When you power up there should be a message that includes the firmware revision. I didn't see that listed in your messages. Do you get that far?
The Following User Says Thank You to thingstodo For This Useful Post:
