Old 06-05-2008, 11:47 AM   #81 (permalink)
LMGDM - '97 Sentra
Yes, COM1 gets removed from the list when I unplug the cable. Not sure if I said this before, but I wired up the ends of my serial cable as a test plug (handshaking lines tied together and rx tied to tx and I received back what I was sending with the Arduino serial monitor, so I'm pretty sure I'm transmitting and receiving correctly on the USB to serial link.
I don't need to put any jumpers on for the serial version of the board, right? Just if using external power on the USB version?
Also, I was foolish enough to order the serial version before I checked to see if either of my computers had a serial port, that's why I'm doing the USB to serial converter cable. If worst comes to worst, I suppose I'll just have to buy the USB kit, though that's basically doubling the money I've already sunk into this.
Old 06-05-2008, 12:14 PM   #82 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Well, it isn't all bad. If you buy a USB one (with the dip socket), you can use it to program just the chip for the serial one, then put the serial one in your car and you will still have an arduino on your desk to play with
Old 06-05-2008, 03:50 PM   #83 (permalink)
FuelSipper
HondaHokie - '95 Accord DX 4 door
90 day: 26.91 mpg (US)
Here is another *duino that is cheap and has a very small form factor. From Makezine...
http://www.makershed.com/ProductDeta...ductCode=MKAD9
Old 06-09-2008, 02:18 PM   #84 (permalink)
FuelSipper
Project enclosure ideas from Sparkfun
Sparkfun has a great tutorial on finding out the right enclosure for your project. I thought this could be a useful reference for the Opengauge.
http://www.sparkfun.com/commerce/pre...e-Modification
Old 06-09-2008, 03:05 PM   #85 (permalink)
dcb
needs more cowbell
dcb's Avatar
Here is another small form factor duino that looks like a real bargain @ < $18.00. It comes with usb connector and would fit behind a 2x16 LCD:
http://www.spiffie.org/kits/iduino/
Old 06-23-2008, 07:40 PM   #86 (permalink)
Originally Posted by jimboradley View Post
...a USB to serial converter cable...
Originally Posted by dcb View Post
Has anyone else here tried this configuration?
I am currently using a USB to Serial adapter to program my arduino. It doesn't work "out of the box", but if you aren't afraid to open it up and get a little dirty, you can make it work. I have a write-up on my site that will show you what to do. The chipset may be different, but the basic concept will still apply.
Hope this helps!
http://sites.google.com/site/brandon...ronic/usbtottl
Old 06-23-2008, 09:08 PM   #87 (permalink)
dcb
needs more cowbell
dcb's Avatar
Wow, you totally owned that USB adapter
I might suggest a USB to TTL kit for $7.90 though
http://www.spiffie.org/store/index.p...products_id=13
(or the assembled one for $11 if you don't like SMD kits)
Old 06-24-2008, 12:37 PM   #88 (permalink)
By no means is my hacked adapter the most suitable solution!
There are lots of other options out there, including the ones posted above. In my case, I didn't feel like waiting to have one shipped, so I figured out how to do it with what I had on hand. I'm slightly insane that way, spending way more time and effort (and sometimes $$$) to reinvent the wheel!
But hey! I have tons of fun doing it, and it is also furthering my self-education in electronics.
Old 06-26-2008, 10:14 PM   #89 (permalink)
dcb
needs more cowbell
dcb's Avatar
Well, it is nowhere near as crunchy as your rig, but I'm using the iduino as a USB p4 type programmer at the moment (reset button works too ):
