Old 06-14-2010, 01:44 PM   #1 (permalink)
Aspiring EcoModder
Eggy - '99 SL2
90 day: 43.7 mpg (US)
Opinions on grill block options
Just wanted to see what your thoughts were on my grill block for Saturn SL2. Please see pictures. One is stock photo and the other is the grill block options specifically targeting how to block the two very wide and narrow ovals.
Also, I'm wrapping up my wooden body pan ... not sure if that would affect which grill block is used.
Old 06-14-2010, 02:06 PM   #2 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
sl2eggplant -
Option B is good. You can also use pipe-insulation tubing to block the grill. It's dark-colored so it's "stealthy", you can just wedge it in without gluing, and it's easy to yank out if you are overheating.
CarloSW2
American Solar Energy Society
Old 06-14-2010, 02:11 PM   #3 (permalink)
Aspiring EcoModder
Eggy - '99 SL2
Thats a great tip CFG. Finally have some use for the left over pipe insulation in the basement.
Old 06-14-2010, 02:21 PM   #4 (permalink)
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
all in all i don't think there's a huge difference, but perhaps having a look at how the actual radiator is positioned could be helpfull... on some cars this is set slightly to one side.
perhaps it's also a good idea to trace where the engine pickes up it's air. on my car this is in the same cavity as the radiator sits and leave an opening closer to that.
i've seen a few cars with assymetric factory grillblocks, so i don't think symetry other than visual has a big imact either.
aerˇoˇdyˇnamˇics: the science of passing gass
*i can coast for miles and miles and miles*
Old 06-15-2010, 01:47 PM   #5 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
I'd focus on giving the air a direct, smooth duct to the rad. That probably favours "A."
Old 06-15-2010, 11:42 PM   #6 (permalink)
Aspiring EcoModder
Eggy - '99 SL2
Bicycle Bob, thanks for reminding me to insert a guide for the air flow. I've been busy tweaking my fully belly pan and forgot about that.
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 02:03 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
Tacoma Grill Block mjboks Aerodynamics 6 01-11-2010 09:44 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
