Old 01-05-2009, 09:12 PM   #1 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Optima Red top = Garbage
Returned my 4th one to advance auto parts on Saturday in 18 months.
All of them end up with a shorted cell. err
As an experiment I left the last one on my back porch for 6 weeks not connected to anything, tried to charge it and discovered a shorted cell.
As another experiment I've been running my Supra (Golf has a conventional battery) on a walmart lawn and garden battery for 2 months. It hasn't had an issue yet.
So be aware.
6 speed ALH TDI
Old 01-05-2009, 09:46 PM   #2 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
I've never seen reports of that many failed batteries from Optima - and I used to sell them at Sears.
You should have your charging system checked, honestly. There might be a problem w/ the Voltage regulator or Alternator, or even a bad ground that is charging the batteries higher than it should be... they can't take more than 15V, and they're only rated for 14.6 cVDC without failing.
Old 01-05-2009, 09:49 PM   #3 (permalink)
Steve - '92 Festiva
Then again, maybe you should get your money back from them, since I just noticed you didn't even use the last one, and it was still shorted, then go to another store that sells them and make sure you didn't just get into a defective batch.
The Red's aren't the most popular batteries compared to many other types, and you could possibly have gotten a complete batch of batteries to fail on you if you kept going with it, due to the relative lack of sales activity compared to other types of standard batteries.
If, in fact, you got into a bad batch, you might find a good one at another dealer, and you'll still be covered under warranty.
Old 01-05-2009, 09:58 PM   #4 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
I'm an ASE certified auto parts specialist, and an engineer. I have to agree with the Christ. Optima != garbage. I've seen lots of cases of Optimae testing bad, then being thrown on the slow-charger over night, and subsequently testing good and working fine.
That said, I don't recommend the Optima to most people. AGM batteries are really neat technology, but the vast majority of people who buy them, don't really benefit from those advantages (nonspillable, vibration resistant, the yellow-top are deep-cycleable).
One downside of the Optima is that fast-charging it kills it. The other downside is it's twice the price of a conventional battery.
Regarding the lawn & garden battery: That's probably rated for 300CCA or so. It'll work fine for now, but I bet it'll be unable to start the car next winter. Undersized batteries don't last, for whatever reasons.
Old 01-05-2009, 10:00 PM   #5 (permalink)
Left Lane Ecodriver
Also, you can test the bad batch theory by checking the date code on the batteries. I'm willing to bet your local Advance doesn't stock more than one or two of them, so I'm pretty sure your batteries came off of different shipments.
Old 01-05-2009, 10:07 PM   #6 (permalink)
Steve - '92 Festiva
Does it get cold in Louisiana? I don't think "winter" is an issue LOL.
If you do end up having a problem with starting in the winter (whatever you call it) you can always link another L/G battery in parallel w/ the one you have... this will double the cranking amp output for you, while maintaining 12V, and should start your car just fine.
Old 01-05-2009, 10:21 PM   #7 (permalink)
6 speed Diesel FTW!
Diesel
Alternator will peak around 14.7 on dash 14.4 97% of the time.
Honestly 2 have never been in the car.
Honestly the Lawn and Garden battery has not failed yet.
This is my 3rd optima red top the the first 2 lasted until I sold the cars . I'm under the impression that they *were* great.
6 speed ALH TDI
Old 01-05-2009, 10:24 PM   #8 (permalink)
6 speed Diesel FTW!
Diesel
Then again, maybe you should get your money back from them,.
Wish I had read this before my last response . . . .
I should have mentioned before my discussion with the manager of Advance Auto parts here in town. They are returning them like mad (don't bother checking them) but are not allowed to return them for money/ credit after 90 days.
6 speed ALH TDI
Old 01-05-2009, 10:39 PM   #9 (permalink)
6 speed Diesel FTW!
Diesel
Interesting My charger is "Fully automatic" which basically just means it pours 25.7 amps in to it until it is almost all the way charged, then tapers off. Could be my issue.
These guys Charging an Optima or AGM Battery : Batteries Are Us recommend charging at a minimum of 100 amps. No Idea who is right . . . . .
I started buying them when I was on a crazy weight reduction kick (drag racing). I was actually pretty loyal to them for a while
Not to doubt at all, but do you have a source?
Just ran across these 2 on their page.
News, Events, FAQ
News, Events, FAQ
No doubt it is not intended for automotive use; but it works much longer than any optima has so far. I'm actually considering leaving it because it never gets very cold here and I never drive it when it is "cold".
6 speed ALH TDI
Old 01-05-2009, 10:42 PM   #10 (permalink)
6 speed Diesel FTW!
Diesel
I totally did not think about that. I have not tracked any info from the previous batteries.
6 speed ALH TDI
How to Repair an Optima Yellow Top bennelson DIY / How-to 13 03-06-2009 11:00 AM
EcoModder iPhone/iPod Touch Theme! SVOboy Forum News & Feedback 1 08-12-2008 10:58 PM
