Old 01-21-2010, 03:00 PM   #161 (permalink)
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
I seem to be making some mileage headway with the pre warming. 6.3 L/100K cold 5.3 L/100K warm. So far this is what I have done:
Grille blocks. Upper is two pieces of closed cell 3/4" pipe insulation. they fit right in woth some judicious slots cut for the little grille tabs. Lower is an internal coroplast piece screwed to the honeycomb. there is a 6" section left open for a bit of cooling. I'd like to make this adjustable.
Engine blanket. This is 3 pieces of sound deadening material with foil on the engine side and a layer of rubber between. This is great at keeping the engine warm during stops.
Gap sealing around headlights and hood. This keeps the warm air from escaping and it really helps.
Front belly pan in coroplast. Keeps drafts out.
Passive inline coolant heater. AKA lower radiator hose heater. I have this installed on my upper hose though because the Prius has it's thermostat where the lower hose enters the engine. Gives me about +20˚C coolant temperature.
To do:
Block heater
Tank/circulation engine heater for the transaxle. Since I already have the engine preheat sort of worked out I will try the circulation heater in the tranny because it hasn't been tried AFAIK. (plus it's easier to set up) As Bob and others have documented, the cold tranny eats a lot of energy. Since I already have the synthetic WS ATF in there, warming is the next step.
Oil pan heater for both the transaxle and the engine.
Better get going...
Old 01-22-2010, 09:28 PM   #162 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
That must have been satisfying to see those 80+ mpg segments in pulse & glide mode. Congrats.
Keep reminding yourself: in general, the purpose of winter is to give you a deeper appreciation of fine summer weather.
Old 01-22-2010, 11:57 PM   #163 (permalink)
marcusmodder
orange4boy's Avatar
Chewie - '03 Prius
90 day: 57 mpg (US)
Transaxle pre-warming thread
It was gratifying, while it lasted. I was beginning to think there was something wrong with the Prius... or my foot.
Old 01-23-2010, 03:31 PM   #164 (permalink)
marcusmodder
orange4boy's Avatar
Chewie - '03 Prius
90 day: 57 mpg (US)
Found a very useful graph of tire radius vs inflation pressure for anyone interested in correction factors for tires.
Like me... I just went from the stock size/pressure of 175 65 14 @42psi to 185 65 14 @ 51 psi. I found the revs per mile but not with pressure compensation.
1.5mm change in RR between 35 and 50 psi that works out to:
1737.99mm Dia @ 35
1747.41mm Dia @ 50
difference is .5% rolling diameter. meh.
Original tires Bridgestone RE92 175 65 14 xl: 902 rev/mile
New tires: Nokian WR g2 185 65 14 xl: 884 rev/mile
2% correction for tire size and .5% for pressure= 2.5% total correction.
The Following User Says Thank You to orange4boy For This Useful Post:
MetroMPG (01-26-2010)
Old 01-26-2010, 11:10 AM   #165 (permalink)
That's worth its own thread... I'm going to copy it over.
