Old 10-29-2008, 09:33 AM   #1 (permalink)
Modding for Eris
Thalass's Avatar
Stockie - '00 Outback GX
90 day: 21.25 mpg (US)
Wife's Car - '06 Corolla
90 day: 34.11 mpg (US)
Horse - '98 GPX-250
Outback aeromod advice?
Hey folks. I've gotten to the point where I want to do some minor aeromods on my car. I don't want to permanently change anything, though.
Here's the front view, not as centred as I thought it was .
I was thinking of blocking the lower bumper opening, as all it does is collect sand in the bush and the radiator doesn't extend that low. I was thinking styrofoam with some kind of tape protecting it and holding it in (also to conceal it, I'd like to keep a stock look). The upper grille is needed, though, as it's coming into summer and it's going to be up towards 42°C in a month or so. Also the fog lights - A clear cover for those if I can get something. The wipers would be a good idea, too, but I'm not sure how to build something to cover them.
Here's the other thing I'd like to fiddle with. I don't want to remove the bars, but I think plugging those holes would help. I can get some clear tape that should cover it nicely, but perhaps some foam or something to strengthen it will help.
Here's another view of it.
Here's the view from underneath the front. The plastic bash plate doesn't protect the car very well from impacts, but probably helps aerodynamically. Probably not much, though.
So would these things be worth it? Is there anything else anyone can see? The mirrors do fold in, but I'd rather keep them out, unless I can have them deploy when I push a button or something
Completely stock '99 Outback!
Electric 4WD on the moon! Win!
Old 10-29-2008, 10:59 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
I'd suggest blocking the upper grill opening. It has more aero benefits. Blocking the bottom isn't going to do much for you except speed up warm up times.
Old 11-01-2008, 08:46 PM   #3 (permalink)
saturn - '99 sc1
90 day: 35.67 mpg (US)
why not do the lower? i'd say do the lower, and an adjustable / easily removable upper. i think the hottest days are the best for making a grill block, once you've seen how far you can go in the most extreme conditions you can go ahead and make it permanent.
Old 11-01-2008, 09:05 PM   #4 (permalink)
Ohh snap
brucey's Avatar
Lesbaru - '00 Outback
90 day: 21.98 mpg (US)
Summer - '00 Cavalier Z24 Convertible
90 day: 29.82 mpg (US)
Send a message via AIM to brucey
Mine looks like this in summer:
coolant never gets above 212F degrees
Recently I've taped the bottom half up too as its winter, now it doesent get above 204F
Old 11-02-2008, 05:27 AM   #5 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 59.38 mpg (US)
[Thalass], think about cutting the passenger side mirror and replacing it with internals.
Piwoslaw's Peugeot 307sw modding thread
Old 11-04-2008, 07:33 PM   #6 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
If you can live with less ground clearance, I'd suggest struts and springs from a non-Outback Legacy (Liberty). It's a direct swap, and you can probably find them in a junkyard.
Old 11-04-2008, 09:12 PM   #7 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 scenic
90 day: 43.09 mpg (US)
megane - '97 megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Prius
90 day: 55.12 mpg (US)
Something I'd like to be able to explain.
I imagine that if I have a good upper grill blocking, in a aero point of view, I should avoid having wipers in the air flow.
Denis, who can't wait his aero book to travel the Atlantic Ocean...
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 11-04-2008, 10:26 PM   #8 (permalink)
First, drop that sucka! You are lucky enough to have the power of the entire Subaru aftermarket at your disposal. You can choose from a variety of springs, struts, or even coilovers.
Second, there should be aluminum skidplates available for your car. Most Subaru skidplates extend to the front jacking plate (under your steering rack). The engine cradle/subframe and exhaust manifold hang down in the breeze a bit. A skidplate will clean this up and insulate your oil pan a bit. Your car isn't going to overheat, but should run nice and warm just the way you want it for mileage.
Third, look on the Legacy forums to see if there are any factory parts to plug the holes when you remove your roof rack.
Next, look at your options for another bumper cover. There were several legacy models. IIRC, some Legacy models cam without fog lights. Some had a much lower front lip (built-in airdam). You're grille insert can also be snapped out and replaced with other models.
You can easily and cheaply space your hood if you don't mind the way it looks.
Other than that, you might want to check out the black plastic around the wheel wells. Both sides of the engine are blocked from wheel wells by plastic panels.
Old 11-25-2008, 04:55 PM   #9 (permalink)
papa smurf - '81 pickup 4wd dlx long bed 1/2 ton
90 day: 18.11 mpg (US)
Heep - '011 Grand cherokee Larado x
90 day: 19.31 mpg (US)
Da bike - '06 Shadow Vlx deluxe
90 day: 53.94 mpg (US)
dude is your car in logan ? near one stop? wont say whose house.
i am 99% sure it is u, i like the front bumper, doesnt stand out too much.
2011 Jeep grandcherokee larado x v6 4x4. (wifes/weekender)
98 taco base 4x4 i4 toyota bought back due to a rust spot. gone but not forgotten.
81 toyota 4wd long bed 1/2 ton
Old 11-27-2008, 04:52 PM   #10 (permalink)
Ohh snap
brucey's Avatar
Yup. Went down there to see my family. PM Me if you wanna talky more.
1992 Metro sedan needs a new engine - What/Where/How - advice appreciated greatly! Crono EcoModding Central 26 11-18-2008 02:42 AM
Road Bike Update (and asking for more advice) GenKreton Alternative Transportation 7 09-03-2008 05:40 PM
CV boots-need mechanical advice please Cd Off-Topic Tech 30 06-30-2008 12:19 AM
Road Bicycle Buying Advice GenKreton Alternative Transportation 67 02-26-2008 09:40 PM
X-Prize team is looking for advice AD5OS General Efficiency Discussion 24 01-16-2008 10:48 PM
