Old 04-24-2009, 01:41 PM   #1 (permalink)
Manic Rabbit
Southcross's Avatar
Slow-n-Low - '81 Rabbit S
90 day: 33.97 mpg (US)
Oxygen Sensor Brands
I've searched... and every "Brand" says their product is superior to "other brands"
seriously... If my choices were Denso, Bosch, or NGK/NTK... and lets say they were the same price, same "universal" wiring... is there a "better" sensor for my buck?
-Edward
Driven on Colorado roads, where NOTHING is flat
Present City 3x / Highway 4x
Goal: 4x / 5x
Old 04-24-2009, 01:48 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
All I know is that for lean-burn-using Hondas the Bosch sensors just won't work because they aren't made precise enough for the rest of the equipment.
Old 04-24-2009, 01:48 PM   #3 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
At that point I'd go with whatever one is in stock. I really don't think it matters.
Old 04-24-2009, 02:12 PM   #4 (permalink)
Manic Rabbit
Southcross's Avatar
thats what I'm thinking.... I'm thinking of going "which ever is least detrimental to my pocketbook"... LOL
I'm just currious if someone out there would say "ya, I had tried two different XXXX and YYYY brands and found that YYYY did ZZZZ"
-Edward
Goal: 4x / 5x
Old 04-24-2009, 02:20 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
SVOboy -
I've heard the same. For my Saturn, I should have gotten the OEM Denso, but I got a universal Bosch. Maybe once a month I throw a code P0410 (secondary injection system failure/error). But I know from research that this is because the Bosch doesn't respond fast enough during startup testing. I just clear the error and ignore it, but it is annoying.
Unless you have definitive proof about brand "X", I would go with the OEM brand.
CarloSW2
American Solar Energy Society
Old 04-24-2009, 02:30 PM   #6 (permalink)
Manic Rabbit
Southcross's Avatar
OEM brand is Bosch... but I'm "modifying" my setup for better cold FE. You would have to know the caveats of single wire vs multi-wire (heated) O2s. a Heated O2 may improve my FE allowing me to set the ECU to Closed Loop sooner
anywaysies... I'm even contemplating going "Cheap eBay", I think that's what I have in there now (single wire version):
eBay Motors: NEW BORG WARNER UNIVERSAL 3 WIRE OXYGEN SENSOR! (item 150271642570 end time May-11-09 22:10:13 PDT)
-Edward
Goal: 4x / 5x
Old 04-24-2009, 02:47 PM   #7 (permalink)
Dartmouth 2010
SVOboy's Avatar
3 wire!? I've never heard of such a thing.
Old 04-24-2009, 02:55 PM   #8 (permalink)
CM400E - '81 CM400E
1 signal wire, grounds to the exhaust system. 2 wires for the heating element.
Old 04-24-2009, 03:03 PM   #9 (permalink)
Manic Rabbit
Southcross's Avatar
1 - Signal only
2 - Signal, Shield
3 - Signal, Heat & Ground
4 - Signal, Shield, Heat & Ground
5 - typically wideband (don't know the pinout off the top of my head)
-Edward
Goal: 4x / 5x
Old 04-24-2009, 04:25 PM   #10 (permalink)
Pokémoderator
cfg83's Avatar
Southcross -
I've also considered that and should probably do it. My post-cat is a heated 4-wire sensor.
My reason would be a little different. A while back RH77 reminded me that extensive use of EOC (engine off coasting) can cool the 1-wire 02 sensor and push you more into open-loop conditions. One that stays heated would be immune to EOC.
CarloSW2
Dry Ice in Intake? superchow EcoModding Central 41 08-01-2011 11:12 AM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 01:39 PM
Catalytic converter or oxygen sensor? rick390 Off-Topic Tech 8 12-09-2009 11:11 PM
D15Z1 Engine surging, help needed... socalsuperhero EcoModding Central 28 10-14-2008 08:08 PM
Oxygen sensor gauge reading at wider throttle openings markweatherill Instrumentation 4 08-28-2008 06:18 PM
