Old 09-19-2010, 09:57 AM   #1 (permalink)
P07 or P08 ECU for Japanese VTEC-E?
Thanks for the answers to my "VX engine not performing", my engine is a Japanese VTEC-E (D15B block & P07 heads). I know I have the wrong exhaust manifold (4 into 2), and 4 wire O2 sensor. Now I need to know about the ECU, I have a P08, it seems from everything I read yesterday that I should have a P07, can anyone confirm that? I really want to get the great mileage this engine's known for, but I need the right parts because I'm not getting great mileage now!
Old 09-19-2010, 11:55 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
I used a p07 with my japanese import d15z1. Dunno about the p08, but the p07 worked for me.
Old 09-19-2010, 02:08 PM   #3 (permalink)
Try posting question here too, you might get more response as honda ECU is all they know .
So your engine is one with only 1 intake valve opens till 2500 rpm them both intake work ,all 4 valves work per cylinder .
Hondata :: Index
Old 09-25-2010, 01:00 AM   #4 (permalink)
Thanks for the Hondata site but I couldn't answer their trivia/anti-spam question! Anyway now I have the P07 ECU, but I can't find an original exhaust manifold but I think I'll modify a regular 4 into 1. Also they blanked off the EGR valve and I think I should put it back.
All o dat, soon come, mon!
Old 09-25-2010, 08:48 PM   #5 (permalink)
The Beater - '99 Civic EX
90 day: 39.89 mpg (US)
the biggest thing thats going to kill your mpgs is not having the correct wideband with that ecu. you might have to rewire from the o2 sensor to the ecu if its not an original vx wiring harness. If that o2 sensor is not the wideband or wired correctly i'm pretty sure lean burn won't work.. so it will get the same gas mileage as the non lean burn models....
Ben
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 52 05-18-2012 12:52 PM
1994 Honda Civic D15 3-STAGE VTEC TURBO 55+ MPG FullRacePhil For Sale 18 03-03-2012 08:18 PM
MPGuino for Audi rmccomiskie OpenGauge / MPGuino FE computer 40 05-22-2011 09:18 PM
Reprogramming US ECU maps on 3.8 Buick with european, possible? rmay635703 EcoModding Central 0 06-18-2009 12:38 PM
The "right" way to tap into ECU...? NachtRitter Instrumentation 6 02-05-2009 02:42 PM
