P07 wiring questions
1st post here, a little about my setup...
I've got
A 90 Crx dx, it had a b18b1 in it and sucked at FE (26-29mpg)
So I sold the b18 and bought a d15z1 (jdm d15b)30k mi) an 88 HF tranny(58k mi), new clutch kit, new axles, new wheel bearings, plug wires, starter, alt, belts and a 195* thermostat.
Ive got the old out and the new In, I'm at the stage where I still have to solder a few plugs And harnesses in.
I'm trying to wire up my p07 to a d15z1 in a 90 Crx,
I need to know the pinout for a lean-burn "on" light, vtec "on" light and upshift light.
Any ideas? It's the p07-a00 model ecu
And what sort of relay could/should I use to power the led's? I've used a ton of 87a relays so I understand how they work.
The link in the mods list is down...
