Old 02-18-2009, 01:51 AM   #11 (permalink)
WonderWagon - '94 Escort LX
Last 3: 51.52 mpg (US)
DaRedOne - '99 Escort ZX2 Hot
DaBluOne - '99 Escort SE
90 day: 48.97 mpg (US)
Originally Posted by jesse.rizzo View Post
Testdrive: Is it possible the belt is slipping without it making that horrible belt slipping noise?
Not sure about modern style serpentine belts. Haven't seen it / heard it, but I pretty much just work on my own stuff now-a-days. It was/is 100% possible with older style v-belts on 1950s - 1980s vintage vehicles. For v-belts that behaved that way, the working surface of the belt always had a hard, shiny surface when it slipped but made no noise.
Old 02-18-2009, 02:55 PM   #12 (permalink)
F150 - '97 F150 Lariat
Taurus - '02 Taurus SE
the 73 - '73 Thunderbird
the race car - '95 Thunderbird LX
The Brick - '98 LeSabre Limited
Originally Posted by winkosmosis View Post
I disagree that a full block is better than partial any day or that grill blocks are universally better than air going through the grill.
The car and the airflow around it don't care whether there is turbulence under the hood. All that matters to the aerodynamics are
1- the resistance that air encounters when trying to enter the radiator. This is a factor of the restrictiveness of the radiator and the hardware behind it.
2- the way air flows over the grill if it doesn't go through.
3- the path of air as it comes out from underneath the car, the back end of the hood, or the wheel wells
If the resistance is high enough, it will be like a virtual grill block that some people attach behind the grill... If it's low enough, the grill would present a nice hole for airflow.
Now, on an angled surface like his upper grill, blocking that off would help, because it's easy to cut through air with a wedge. It would also have the benefit that the air coming up from the bumper would remain smooth, instead of being disturbed by the grill.
But blocking the lower grill under the bumper forces that air to move down or to the sides. The easiest path here is probably downward, especially for the center. That air would compress, go under the car, and be forced out the sides, possibly increasing drag. It could also be forced down and to the sides at an angle, into the tires.
The center of his grill is nearly vertical and flat. The car has to force this air toward the sides and downward. If he removes this, the sides will still help aerodynamics, and the small stream of air flowing through that opening would encounter less resistance proportionally. Also, the fan might be able to suck all the air it needs through the hole even if it is smaller than normal.
your username sounds so familar.....are you on any other local boards?
Old 02-18-2009, 05:12 PM   #13 (permalink)
I'm not on any Texas boards. I use this UN on Miata.net, Jeepforum, Scale4x4rc, gassavers.org, and probably some others
Jetta TDI Duct Tape Mods Sayyad Aerodynamics 31 09-22-2011 09:46 PM
Grille Block Sunwapta Aerodynamics 5 12-24-2008 09:46 AM
Temperature controlled grille block Piwoslaw Aerodynamics 19 11-09-2008 10:24 PM
Grille block: front or back and top or bottom? 07b2300 Aerodynamics 11 07-07-2008 10:19 PM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 10:14 AM
