Old 01-03-2009, 07:04 PM   #101 (permalink)
Blackfly - '98 Metro
90 day: 78.84 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 106.27 mpg (US)
Uh oh: Ben, I clicked the "Contribute Here" link to adopt a Mosfet, and I got this error at PayPal:
Sorry — your last action could not be completed
Old 01-03-2009, 08:59 PM   #102 (permalink)
Fossil-Fuel Optional
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 26.95 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
DOH! And I made this great video about it any everything!!!
It worked when I contributed! Back to the PayPal drawing board again!
Old 01-03-2009, 09:17 PM   #103 (permalink)
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
Ben, you are awesome
Heck, I'll say it again! Ben, you are awesome! Your videos are so professional looking! We really appreciate your help!
I think the button from greencarvideos.blogspot.com works, it's just the other link (on the earlier post here on ecomodder) that doesn't.
As I watch the old man walk on the sidewalk below my window, I think "Some day old man, I will be like you. So why not give me your coat?" Then I go downstairs to get his coat, but he's gone. Hey, maybe he was Zorro.
website!
Old 01-03-2009, 09:39 PM   #104 (permalink)
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Intrigue GX
90 day: 25.35 mpg (US)
I made it happen... finally...
I tried the quick link and got the same message, even when already logged on to PayPal. I then clicked on Ben's webpage link, clicked on the "Donate Now", and just copied Paul's PayPal link from there, then pasted it into the PayPal "send money" page I already had up (Just ordered my t-shirt!). Seemed to work okay then...
I'm guessing the easiest way would be just to put Paul's (email or eBay ID) name on the Mosfet page. It's Mosfetational!!!
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
Old 01-03-2009, 10:22 PM   #105 (permalink)
bennelson's Avatar
S10 - '95 S10
I removed the quick link I posted earlier. The DONATE button on my blog seems to be working fine.
Hopefully, it will get hot from so many people clicking it.
Old 01-03-2009, 10:27 PM   #106 (permalink)
Yup, the button link on Ben's blog page worked for me. I just adopted one.
I've decided to name mine "Little Miss Mosfet":
Little Miss Mosfet
Sat on a circuit
Doing what Paul did say.
Then along came a V spike!
Which, no, she did did not like.
Her smoke got out and blew away!
Old 01-03-2009, 10:41 PM   #107 (permalink)
PaulH
oh, those voltage spikes make me real mad!
Thank you everyone! There are now about 2.2 out of 10 mosfets sponsored! I'm going to learn as much as I can about how not to make these cheap ones fail so I don't leave a man behind!
Update: I'm hooking up the Hall Effect current sensor, even though it did get pretty dang hot on an earlier soldering attempt. Assuming it isn't barbecued, I will get a good idea about how much current each mosfet can handle. I'll program it to limit current to 5 and then 10, 15, 20, etc... until it dies???? hmm... that seems a bit harsh. I'll do something similar on the car's version, even though Ian's results with those 200v mosfets says they can handle about 50 amps continuous. It would be good to know for sure in my case, I guess.
website!
Old 01-04-2009, 12:43 AM   #108 (permalink)
PaulH
Current limiting implemented!
I thought I cooked the current sensor, but it still works! Bam! The specs say you can store the dang thing at 180 degC! That should have been a clue that it's sort of big, bad, and feisty!
So, With the single mosfet, I powered the bike with limiting the current to 10 amps, and it seemed slower than with no current limiting, so then I changed it to limit the current to 1 amp, and the little wheel would barely turn! haha! The brakes were rubbing against the rim, so that stopped the poor little 1 amp from doing it's duty! haha! Current limiting is very empowering!
I like the current limiting! and it likes me back!
Plus, the switches are super clean and good and easy to use! Sort of sloppy still, but it's all good. The switch on the left is for the pre-charge resistor. The middle switch is for turning on the controller. The right switch is like the contactor in a car when you turn the key.
There's also a picture of the ATMega8 micro-controller being programmed IN SYSTEM!!! No more unplugging it! ya! I need to clean up the interface for the in system programming, hehehe... but whatever, Back off, you red-headed stepchild!
website!
Old 01-04-2009, 07:02 PM   #109 (permalink)
PaulH
Successful Test at 60 volts!
I rewrote the whole micro-controller program to clean things up a bit. Then I tested the single 100v mosfet controller at 12v, 24v, 36v, 48v, and 60v. It worked perfectly! I set the current limit to 5 amps. When I slowed the wheel down with my hand, you could hear the 4kHz tone get quieter as the current limiting was kicking in and automatically cutting back on the throttle. I would have tested it at 72v, but I ran out of those wire connector things that you can see in the picture, so I couldn't hook up the 6th battery! Oh, that makes me real mad inside!
I'm amazed at how low the amps can be at high voltage to still get excellent performance. It's also amazing that all that power is going through a single mosfet!
I attached the current version of the software, heavily commented.
I was thinking for a kit, buying the stuff in bulk would cut like $50-$100 off the $350 pricetag. I wonder if that will be possible.
website!
Last edited by MPaulHolmes; 01-04-2009 at 09:46 PM.. Reason: Added software attachment
Old 01-04-2009, 10:42 PM   #110 (permalink)
Intrigued's Avatar
Now's the Perfect Time!!!
Originally Posted by MPaulHolmes View Post
I Then I tested the single 100v mosfet controller at 12v, 24v, 36v, 48v, and 60v. It worked perfectly! I set the current limit to 5 amps.
Ooooh, Ooooh, Pick Me!!! No, Wait... I mean, you gotta try something!!! This is the perfect time to do some research on something I've been hearing about, but haven't seen any real proof yet.
Could you try running the bike wheel at different voltages, but with the same WATTAGE? I hear that amperage is preferred over voltage, and vice versa, but just realized that you could find out what kind of power the wheel has at the different voltages if the wattage is the same. You know, like 12v/10 amps vs. 24v/5 amps and so on up to 60v/2 amps. These would all be 120 watts. I would REALLY be interested!
This might not prove anything but how that particular kind of motor works, but it would still be neat to know!!!
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 69 Yesterday 11:48 AM
Contest! Name Paul & Sabrina's controller MetroMPG Forum News & Feedback 104 10-02-2009 01:18 AM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 496 09-27-2009 12:15 AM
car hire in orlando
Check out the advantages of car hire in Orlando and get more out of your trip. There's more than theme parks to see!
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
