Old 11-03-2009, 03:15 PM   #11 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Originally Posted by sawickm View Post
I would be willing to donate to the cause, give me a list and count of the parts you need to get started.
Thats a good idea. It helped get the first controller off the ground a little faster. Ben, do you still have that link to donate to Paul setup on your site?
Old 11-03-2009, 03:16 PM   #12 (permalink)
jackbauer's Avatar
Ok my 2 cents. Small drives are cheap. Whey not look at doing what that guy with the ford siemens motor did and use the control bits from a small drive scaled up with a larger power section.
Old 11-03-2009, 03:36 PM   #13 (permalink)
Originally Posted by MPaulHolmes View Post
4) U.S. Digital encoder, model E3-500-500-IHT. I don't know where to get this. Maybe I'll get a different one.
For start I think you don' t need it because first you will want to run AC motor simple open loop V/Hz method then sensorless Vector control and only then closed loop with sensor (a lot great fun of PID tunning). Not much hardware difference just you have or you don't sensor
It is standard quadrature incremental encoder 500 lines per revolution, 5V supply can be found here:
US Digital | Products » E5 Optical Kit Encoder
Here others from Farnell:
Farnell Export
Yes they are expensive and must search hard to find cheap one
The Following User Says Thank You to Janis For This Useful Post:
MPaulHolmes (11-03-2009)
Old 11-03-2009, 04:19 PM   #14 (permalink)
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
I am doing what someone else did! hehehe. The software is largely done by Microchip. It will at least give me a really really good head start. I've even compiled it in MPLab. So I have the hex file, I'm just waiting to order the PICKIT2 or PICKIT3, and a few other things. And the software has been tested and tuned for a 1/3 HP LEESON motor. It's application note AN908.
I don't think the control section will be very complicated as long as I'm using an integrated driver board/ power section module, which I am. hehe. They even have IGBT 6pacs that go up to 600amp. A 3 phase bridge with drivers and everything in one piece. Just add ripple capacitors. That's not the cheapest way to go, but certainly the easiest.
signature goes here.
Old 11-03-2009, 04:30 PM   #15 (permalink)
What about dedicated DSP for AC motor control, like:
http://www.freescale.com/files/micro...=Documentation
or
http://www.analog.com/static/importe...ts/ADMC326.pdf
Old 11-03-2009, 04:48 PM   #16 (permalink)
PaulH
For me the field oriented control is a must. Fran is helping me out with this, and he uses it in EV PMSM motor control with great success (also with making giant electric mine blower upper machines).
Old 11-03-2009, 09:16 PM   #17 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
This will be great for the day I get around to converting a few alternators to motors.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
The Following User Says Thank You to Christ For This Useful Post:
Intrigued (12-04-2010)
Old 11-05-2009, 06:04 PM   #18 (permalink)
PaulH
sawickm bought a PICKIT3 so I can program that dang PIC microcontroller! Thank you!!!!! I think I'll start out with V/Hz = CONSTANT approach to control, and then add the field oriented control. AFter that, I'm going to try sensorless field oriented control. It's a new area of research right now, and there are some pretty good research papers coming out of some universities in Asia mostly about it that give results that are as good as using a resolver/encoder. I have been reading about how the AC induction motor works, and I keep working on understanding the park and clarke transformations and inverse transforms so I can get a good feel for what's going on.
Old 11-06-2009, 08:45 AM   #19 (permalink)
ReVolt Wiki - Editor
Hi Paul,
As soon as I receive the PICKIT3, I'll send it out to you.
- Mark
Old 11-06-2009, 10:05 AM   #20 (permalink)
PaulH
Pickit.... lickit..... flickit!
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 5532 Yesterday 11:03 PM
Contest! Name Paul & Sabrina's controller MetroMPG Forum News & Feedback 120 10-22-2011 02:59 PM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 527 09-02-2011 03:35 PM
