Old 01-04-2017, 01:47 PM   #2981 (permalink)
motorulf's Avatar
I had apparently mixed up the cables when i checked and fixed the pinout.
no 1 was going to 2 and vice versa.
Now things work better.
It does not run wild and i managed to complete a successful run-pi-test.
I saved
Then i tried run-pi-test2. now it is consuming 60Amps again. rotor vibrating and my thinner "fuse" cables melting. I aborted (cut the power to everything)
I tried to power everything up again, when the contactor closes the motor starts vibrating and humming again, drawing 60 amps.
All the current sensors have connectors pointing towards the IGBT end of the cable.
Going forward though
Yeah, i am only using 25 volts right now, is that too low?
Old 01-04-2017, 02:06 PM   #2982 (permalink)
PaulH
MPaulHolmes's Avatar
Oh dear... Hmm. Could you disconnect a current sensor cable and then turn it on again with 25v? 25v is a good test value. This should cause a hardware fault so that everything should be disabled. What is your 24v source for the control/driver board? It should be isolated from the "high voltage" battery pack (25v at the moment).
kits and boards
Old 01-04-2017, 02:17 PM   #2983 (permalink)
motorulf's Avatar
Unplugged current sensor cable, gave a hardware fault.
24V source is an adjustable power supply 0-30V, 0-10A set at 24.0V.
25V source (HV) is a lipo battery 6 cells 8Ah
12V source (for contactors) is a 15A 5V/12V powersupply
So what is next?
There might not be much more i could possibly be doing wrong. haha
But i am shure there is anyway
The Following User Says Thank You to motorulf For This Useful Post:
MPaulHolmes (01-04-2017)
Old 01-04-2017, 02:21 PM   #2984 (permalink)
PaulH
OK good. I was worried that there was a short on one of the IGBTs.
Are all 3 current sensors oriented just like current sensor #3? (so that the 4 prong plug is on the side closest to the IGBT) So that the arrow on the top of the current sensor points away from the IGBT?
One scary possibility is the current sensor could be damaged if the pins were swapped before. I've destroyed one doing that once, but I've also done it before and then the sensor still worked.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
motorulf (01-04-2017)
Old 01-04-2017, 02:33 PM   #2985 (permalink)
motorulf's Avatar
Yes, all the sensors are as you describe them.
I messured the sensors when given 5V and ground. All measures at 2.5v.
I will try to test them individually while hooking a cable up to a dummy load.
Old 01-04-2017, 03:33 PM   #2986 (permalink)
motorulf's Avatar
I tested all sensors with a AC load, as i do not have a working DC load with more than 1 amp.
All of the sensors measured the same.
My vacuum cleaner did not consume more than 8 amps, but still i got a value out of the sensors. They show 0.016V in AC, 2.5V in DC, all of them...
I am guessing they are either all broken or all still working.
I think they are working.
Any other suggestions?
Old 01-04-2017, 07:23 PM   #2987 (permalink)
PaulH
What PI values did you get when it said it passed the test? Could you try (at least for now)
rotor-time-constant 30
And make sure you have the good Kp and Ki that you found from the PI test. Also make sure it has the correct 2 pole pairs. If you don't type "save" it will go back to defaults.
Also, just to make sure, could you do the following:
stream-mechanical-speed 1
data-stream-period 1000
Then, twist the motor shaft by hand and see which way it thinks is positive rotation, and also verify that it is giving a good value for revolutions per minute. Just to make sure the encoder is working right. Then turn it the other way to verify that it shows negative rpm. Does all of that work?
kits and boards
Old 01-05-2017, 11:57 AM   #2988 (permalink)
motorulf's Avatar
I started the controller with a current sensor disconnected, so it wont draw to much power. Here are my values:
Code:
AC controller firmware, ver. 1.0
High pedal lockout fault.  Ignore this for now.  It's not really a fault.  haha.
There was some hardware caused fault, not originating on the microcontroller (not set
 by me!
config
motor-type=1
kp=41478 ki=00669
current-sensor-amps-per-volt=0320
max-regen-position=0050
min-regen-position=0060
min-throttle-position=0800
max-throttle-position=0820
fault-throttle-position=0020
max-battery-amps=0015 amps
max-battery-amps-regen=0015 amps
max-motor-amps=025 amps
max-motor-amps-regen=025 amps
precharge-time=0050 tenths of a sec
rotor-time-constant=005 ms
pole-pairs=002
max-rpm=06000 rev/min
throttle-type=0
encoder-ticks=0256 ticks/rev
pi-ratio=062
raw-throttle=0369
So then i changed rotor-time-constant to 30, saved, turned off, connected the current sensor, and power it up.
Now the motor spins slowly, not vibrating any more, still makes a humming sound though, and still draws 60A. and as usual just when the contactor closes.
So now i am back at the "original" values:
Code:
motor-type=1
kp=03333 ki=00050
pole-pairs=002
throttle-type=0
pi-ratio=062
I tried the stream-mechanical-speed 1.
Rotating the shaft clockwise gives me positive numbers.
Negative while turning the other way.
i try to rotate at around 1 revoultion / sec and then it shows me around 60 rpm.
Seams to work...
Now with these settings the motor is standing still, I can hear a high pitched noise so i believe it is trying to do something. drawing about 0.3 amps.
Old 01-05-2017, 12:43 PM   #2989 (permalink)
PaulH
OK the Kp 41,000 is way too big. It is probably resulting in some overflows in software. Are you sure that was the result of a PI test? It is supposed to stop at like 17,000 or something like that. I better check the code on that. Stick with The 3333, 50 for this second. It is most likely too small of a value, since the lower the voltage the higher the Kp and Ki required, but let's just see if they work for now.
reconfigure the throttle.
For throttle, if minimum is 300 and maximum is 600, do the following:
max-regen-position 300
min-regen-position 400
min-throttle-position 500
max-throttle-position 600
That will give a good sized deadzone of 401 to 499. Then, if the throttle will stay naturally in the dead zone (no spring pulling it to zero?), type the following:
stream-idref 1
stream-iqref 1
stream-id 1
stream-iq 1
stream-percent-volts 1
stream-raw-throttle 1
Then, slowly give it some throttle until it gets into the 500-600 range. Does it spin? Let data stream for a second while in that range. Could you post that data? It can be saved to file, and pasted into excel (comma delimited), or you coudl just get a screenshot of the streaming data.
EDIT: You found a software bug in the run-pi-test! I'm going to fix that.
kits and boards
The Following 2 Users Say Thank You to MPaulHolmes For This Useful Post:
kalidasbala (03-24-2017), motorulf (01-05-2017)
Old 01-05-2017, 02:11 PM   #2990 (permalink)
motorulf's Avatar
Yes, now itīs working.
I have control over the motor now.
As you can see in the file, i just had to play around with it a bit.
Drawing a maximum of 8-9 amps from battery.
first_run.xls
first_run.csv
MPaulHolmes (01-05-2017)
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 10:55 PM
Contest! Name Paul & Sabrina's controller MetroMPG Forum News & Feedback 120 10-22-2011 01:59 PM
