Old 06-29-2009, 11:35 PM   #1861 (permalink)
Thumbs up
Hey, Paul. sounds like you have some full days ahead. From what I have seen, I am sure you will come up wih something good. Take care, Watt
Old 06-29-2009, 11:57 PM   #1862 (permalink)
Beta-tested it to death!
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
If you want to do something REALLY cool for end caps, make them out of neon green lexan and put a small UV blacklight (fluorescent type) inside.
Otherwise, clear plexi with a few LEDs going into the edge would be cool too!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 06-30-2009, 12:28 AM   #1863 (permalink)
Thumbs up Controller temp tests
I know this is slightly off topic, but I would like to see how the Open Revolt that is going to arizona does. Was getting ready to turn in, and the weather channel was on tv. It was 108 Degrees there today(according to them).WHEW Too hot for me! Have a good one. Watt
Old 06-30-2009, 02:05 AM   #1864 (permalink)
Joe
I do too! My plan is to either start a testing thread or add info/updates in the wiki. or both! Its just starting to get hot, so perfect timing for some "hot day" testing.
Old 06-30-2009, 04:30 PM   #1865 (permalink)
ReVolt Wiki - Editor
Good stuff !!!
Hi Paul,
I am new to this group, the past few days I have finished reading all the thread pages for the Revolt EV Motor Controller. What this group has accomplished is very impressive !!! I would be willing to help on this open source ReVolt project. I have experience in PCB design and electro-mechanical packaging.
Reading through the threads I understand that the Revolt has been designed as a scalable modular EV DC motor controller. Back on some of the earlier threads, there was talk of some different power versions of the Revolt. I believe the power module that you are working on now is rated around 144V @ 500A. What needs to be done to increase the current rating on the ReVolt unit ? Is it just adding more mosfet/diode/capacitor pairs and increasing the current limit range ? Would that require a software change too ?
What is the power rating for a mosfet/diode pair on the present power module ? The irfp4668 mosfet is rated at 130A @ 200V, and the stth6002 diode pair at 60A @ 200V. You said in one of the threads that they were rated around 50 amps per mosfet/diode pair, is this still true ? I am interested in the design of a modular chassis for the ReVolt that would allow you to increase the current rating by adding power module PCB’s (1-mosfet, 1-diode, 2-power capacitors ,1-gate resistor). They would just bolt to the buss bars, and the heatsink. You could repair or upgrade a bad power mosfet by swapping out a power module PCB, not the whole power PCB like you are using now. Using a standard buss bar chassis, the ReVolt could be assembled as a 500A, 750A, 1000A, etc…. controller by just adding additional individual power module PCB’s.
That’s my 2 cents.
PS. Can someone add the latest schematic rev2C to the wiki ???
Old 06-30-2009, 06:10 PM   #1866 (permalink)
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Intrigue GX
Last 3: 25.94 mpg (US)
Hey, Y'all, don't forget that JOB ONE here is to make an AFFORDABLE controller...
Otherwise, I ain't gonna to be able to buy back the two mosfets I sponsored!
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
Old 06-30-2009, 09:43 PM   #1867 (permalink)
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
If we used 2 mosfet drivers instead of just 1, things would be much more scalable. I think your idea would work really well. On the next version, we should really try to use 2 drivers. Ian of Zeva is using 4 right now, for 12 mosfets. It's working really well, and helps to keep things cooler, since he can then afford to use really really small gate resistors. It would require VERY minor software changes.
50 amps per pair seems to be pretty safe. I would really like to change it to synchronous rectification, so we can use a mosfet/mosfet pair instead. The diode is really the weak link.
This sounds like a very good idea. I'm sure it could be made to work. There would only need to be minor changes, like where to put the bolts. If we had 1 bolt per mosfet/diode pair, instead of only like 4 or 5 (or whatever) altogether.
signature goes here.
Old 06-30-2009, 09:54 PM   #1868 (permalink)
That Big Gray Thing - '82 Capri
90 day: 19.33 mpg (US)
Send a message via Yahoo to wolfraven
Still awesome! I can't wait for the synchronous rectification version, especially with MORE POWER, and a fully modular approach to that would be just insane...but I've seen a great deal of other things get going and take a lot longer just to get somewhere...keep up the great work! I'm still saving for my EV >.< But I want to use a ReVolt controller, mostly because it's awesome.
Old 07-01-2009, 02:07 AM   #1869 (permalink)
PaulH
Ben's is getting close to being done (sort of close). That 3/8" aluminum plate came today, so I need to cut it and drill the holes. Also, I need to widen the bottom of the holes of the plate for Joe so little screws can be put through the bottom to hold the enclosure in place. Here's a picture of Ben's. I couldn't find the camera for a long time! makes me mad!
Old 07-01-2009, 05:33 AM   #1870 (permalink)
Paul (and others),
Is there a particular reason that a diode pair per MOSFET is used, rather than one higher rated device? That is a single device to protect the whole array of MOSFETs
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 671 Yesterday 06:57 AM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 527 09-02-2011 03:35 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 05:10 PM
