Old 07-24-2009, 12:25 AM   #2081 (permalink)
You should be able to measure the speed that the motor is running approximately, by applying a short known pulse length to the motor and then measuring the resultant current. The faster the motor is turning the lower the current will be. The current will also be affected by load but it will definitely give you an approximation.
Old 07-24-2009, 12:53 AM   #2082 (permalink)
Originally Posted by MPaulHolmes View Post
Hey squiggles! That's a good question! I should try that.
Also, on the EVTech list, they suggested the following. I'm trying to understand it right now:
What if you lower the motor current limit as the PWM duty cycle
raises, but not in such an extreme fashion?
currentCommand = throttle*(constant - pwmDuty)
or
currentCommand = throttle / (pwmDuty + constant)
The second method is basically what you're currently doing, except
with a constant added to pwmDuty to make the low-rpm behavior act
reasonable.
So, let me see, pwmDuty + constant = throttle / currentCommand
therefore pwmDuty = (throttle / currentCommand ) - constant.
Hmm, I think that is the opposite to what I was suggesting.
In my mind the constant would effectively be the minimum limiting factor for PWM. But it would not need to be applied through the whole process.
I would add to whatever your code is...
If PWM <= 5%
PWM = 5%
or whatever % seems appropriate. Worth a try at least.
Old 07-24-2009, 01:24 AM   #2083 (permalink)
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
I didn't get a chance to try it yet. I had to watch one of the foster kids, who was really really naughty. I had an idea about the throttle.
At 0 rpm, the torque is maximum and rpm is minimum. At max rpm, torque is minimum and rpm is maximum. So, what if we took a cue from the nature of the motor. pwmDuty is proportional to speed, and current is proportional to torque. So what if we tried this:
Try to make:
C*current + (1 - C)*pwmDuty
equal to throttle.
C would be a number from 0 to 1. If throttle was 0, then C would be 0. And if throttle was maximum, then C would be 1. To get this, we could do:
attempt = (throttle*current + (MAX_THROTTLE - throttle)*pwmDuty)/MAX_THROTTLE
Then, you change pwmDuty based on if attempt is too little or too big, compared to throttle.
signature goes here.
Old 07-24-2009, 01:33 AM   #2084 (permalink)
Corolla bandit - '05 Corolla CE
How then do we use the current readings? Near max rpm with normal load, the current should be stable. With no load at max rpm the current should still increase, does that differ from normal load when at an average rpm?
At low rpm the current will increase a lot, will the same thing at no load average rpm?
The first may not be able to stop over-revving the motor, the second may be exactly what Paul wants.
What about the current decay, does it always decay at the same rate as it increases, under the same load and speed?
Paul if you're going to do some testing, I suggest you do the timing thing, or on a button, and then do what mcudogs suggested. Turn on the pwm full, run several concurrent current readings (4 or 5) (should be safe 13*(4 or 5)*adc clock ~65us). Then turn the pwm to 0 and again run several readings. Then go back to normal control. I'd have my hand near the contactor just in case.
Old 07-24-2009, 01:39 AM   #2085 (permalink)
PaulH
Right now I can't do any sort of testing that requires movement. hehe. The serial port is the only way I can hear from the controller right now, and I have 3 old laptops, and none of them have a battery. My extension cord isn't long enough for street testing. I'm saving for one, though.
Old 07-24-2009, 01:54 AM   #2086 (permalink)
What about a radio shack (The Source by CC) cigarette lighter inverter? Probably cheaper than a battery.
I took the liberty of simplifying what you wrote above.
pwmDuty = T/(Tmax - T) * (Cmax - C)/Cmax; except for the possible the divide by zero, this looks good.
Old 07-24-2009, 01:59 AM   #2087 (permalink)
PaulH
CIGARETTE LIGHTER INVERTER!!!!!!! HAHAHA! DUH! EV59RAG ALSO SUGGESTED THAT TO ME, BUT I FORGOT! i'M GOING TO BUY ONE TOMORROW. tHE STUPID PLACE IS CLOSED TONIGHT. DANG IT! YA! hOLY COW i'M EXCITED. YA!
Old 07-24-2009, 02:12 AM   #2088 (permalink)
You can also just wire the power supply for one of your laptops to the main battery pack. (They're universal switching power supplies meaning they can accept either 100-240v AC or 140-370v DC.)
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 07-24-2009, 03:42 AM   #2089 (permalink)
Joe
I found a throttle code that I mostly like - maybe it's a hair too sensitive, but it's good for my rig.
Here's what I was thinking - 500A is needed off the line to get this heavy thing rollin at a reasonable pace, and I don't want to have to floor it to get it. Just feels weird.
You could just set it up so that half of the throttle is active - at half throttle and above, I'd get 500 amps. But, that seems like it'd screw with higher speed driving; Only 150 - 200 amps are needed to cruise, so I'd be trying to nail something like 20% throttle.
To get the best of both I modified the throttle input based on the PWMduty knowing that a zero rpm I have zero PWMduty.
throttlenew=((2*PWMmax - PWMduty)/PWMmax) * throttle
PWMmax is the max bitvalue.
So, when PWMduty is zero, throttlenew=2*throttle, (I'll get full throttle by only pressing halfway).
If PWMduty were it's maximum, that whole mess before 'throttle' would equal 1 and throttlenew = throttle.
The other side effect is that your throttlenew (torque) decreases as you speed up and PWMduty increases. I personally find this nice because it becomes easier to hold the battery amps constant (I try to peg it at 200A during acceleration so as to try to 'baby' the pack). Previously, you had to slowly release the pedal as you accelerate to achieve this (which felt weird). Now, the pedal is more constant.
If I were to change something, I might have 100% throttle at 3/4 PWMduty instead of at PWMdutymax, but I'll leave it like this for now. I imagine it won't be so easy for other vehicle setups, but I'm interested in what other people think about how it feels.
Here's the 3 lines I added (the 1st one is already in there, but I copied it in so it's easy to find where this stuff was added).
rawThrottle = throttlePos >> 1;
throttlePos = (1022-OCR1A)*throttlePos/512;
if(throttlePos > 506)
{throttlePos=506;}
Oh, I also had to make throttlePos a 32bit variable.
Oh, and I changed the ramp to 8 and commented out the ramping if the error was negative, and that fixed the voltage problem I was having and made the throttle more responsive.
ReVolt AZ testing thread:
http://ecomodder.com/forum/showthrea...ting-9325.html
Old 07-24-2009, 09:48 AM   #2090 (permalink)
PaulH
Joe, you are the man! It fixed the voltage problem you were having? You mean the sudden cutoff of 80 amps? or something else. the 80 amp thing has been keeping me up at night!
NiHaoMike! I have a dang 72v pack. boohoo
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 672 02-10-2012 05:41 PM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 527 09-02-2011 03:35 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 05:10 PM
