Old 12-31-2009, 12:56 PM   #2851 (permalink)
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
DOES IT HAVE OVER-REV PROTECTION??!!! Tested and working! Next question! hehe
signature goes here.
Old 12-31-2009, 01:23 PM   #2852 (permalink)
Has anyone come up with a logo design? I have a process I want to test and if it works decently I will make it available for the Re-Volt controller.
John
Old 01-02-2010, 03:27 AM   #2853 (permalink)
Joe
Originally Posted by xtian999 View Post
I hadn't meant that, but I see what you mean. In looking at possible ways to improve cooling, I noticed that the bent portion of the case could provide additional heat sinking if it had some thermal paste where it joins the plate. Also, better air flow inside if the mounting board were perforated. Any objections to swapping some pre-perfed material here?
xtian - i'd recommend a decent sized finned heatsink on the bottom of the controller if you hadn't already planned on one. when you mention perforating the mounting board, i assume that you aren't (since a heatsink would cover the holes anyway).
my heatsink is just a bit larger than the controller base and has 3 high volume computer fans on it. I have a thermal sensor in the heatsink that touches the base of the controller - it reads about 12-15C above ambient temp when continuously pushing 200 amps on the highway. In the AZ summer heat, this setup has never allowed the controller to go into thermal cutback mode while accelerating with high amp draws.
regarding a fan for the controller internals, we previously determined that it wasn't necessary. The primary heat source are the switching components and their primary heat dissipation path is through the heatspreader to the base of the controller and heatsink. Circulating air through the controller wouldn't hurt, but the additional cooling surface area would likely be small compared to a finned heatsink.
The RTD explorer does show the thermistor temperature - if you install a fan for the internals, it should be easy to quantify its effectiveness.
ReVolt AZ testing thread:
http://ecomodder.com/forum/showthrea...ting-9325.html
Old 01-02-2010, 03:33 AM   #2854 (permalink)
Joe
Originally Posted by MPaulHolmes View Post
Every time I get an email or see a post from Joe, or Ben, or you name it! My heart sinks, because I figured its one of those "the controller blew up" letters. haha.
By the way, I'm working on the layout for a synchronous rectification controller right now. I'm using PCB artist, which is free, but pretty easy to use.
haha, i'll be sure to use a proper topic in the subject line!
i'm lookin forward to the release of this high power SR controller!
Old 01-02-2010, 11:15 AM   #2855 (permalink)
Beta-tested it to death!
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
John
I did some work on a logo a while back. The discussion in that part of the thread starts at:
Paul & Sabrina's cheap DIY 144v motor controller
For anyone who is only reading from this end of the thread, here they are:
Everyone has my open permission to use any version of this logo to print out and make any sort of sign, sticker, etc. to go on their controller, car, or window. Just be sure to credit this project and point anyone who asks back here!
If anyone knows somebody who works at a sign shop, it would be great to get a sheet of these printed out and mailed to Paul! Any new controller kits could come with a sticker!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 01-02-2010, 11:24 AM   #2856 (permalink)
jackbauer's Avatar
Very 50's sci fi ben
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
www.evcbr.com
Old 01-02-2010, 12:18 PM   #2857 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Prius
Kopper - '79 Bradley GT-II
Well, lets see if some body will come up with a 2010-ish version.....
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Old 01-02-2010, 07:21 PM   #2858 (permalink)
Logos
Hey Ben, do you have any stickers with wombats on it? Watt.
Old 01-03-2010, 10:38 AM   #2859 (permalink)
well the stickers can also have there web site on them.
especially the window stickers,
(theirs the advertising)
Old 01-03-2010, 10:39 AM   #2860 (permalink)
PS
I like #6 & #7
David
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 672 02-10-2012 05:41 PM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 527 09-02-2011 03:35 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 05:10 PM
