Old 01-17-2010, 09:41 AM   #2881 (permalink)
Custom EV Builder...
Originally Posted by edown View Post
Paul, I just wanted to show you yet another configuration for the power section. The mosfets are only rated at 75 amps, 280 volts, which is why there are so many of them; but at $1.35 each, I thought I would give it a try. One advantage of this configuration is that there are no thermal pads under the diodes or the mosfets, and I have 20 square inches of contact with the heat sinks.
Very nice work.
What do you calculate your peak output at?
Are you using more than one driver for the mosfets?
Old 01-17-2010, 09:58 AM   #2882 (permalink)
EvEagle
I'm hoping for 500 amp, if they blow, I will just put in 10 or 12 of the 130 amp. I'm using 2 drivers (IXDD414PI) 14 amp non-inverting
Evan
Old 01-17-2010, 01:50 PM   #2883 (permalink)
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
Edown, you are the man! My goodness. When people don't hear from you in a while, it's because you are BUSY! Do you have a video camera? I can't wait to hear how it goes!
signature goes here.
Old 01-18-2010, 12:36 AM   #2884 (permalink)
EVVette - '71 Corvette Coupe
If you are using 280V fets, you must be wanting to use a system with higher voltage then 144v??
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
Old 01-18-2010, 09:47 AM   #2885 (permalink)
Evan
Nice
I've got two more weeks and all of my projects at home are wrapped up for a solid 3 months. I can finally focus on the EV project and start building my controller.
Old 01-18-2010, 02:27 PM   #2886 (permalink)
Beta-tested it to death!
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
I just picked up a tablet PC to run RTD Explorer on in my car.
I have it wired up to take power from the car's 12V system.
Besides tweaking the controller and logging data, I also have 27GB of hard disc space for music, sound effects, and EV Build Videos.
Read more on my car's build thread.
I have a video posted there as well.
-Ben
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 01-18-2010, 02:47 PM   #2887 (permalink)
PaulH
Ben, that is so dang awesome. You are the man!!!!! There are a LOT of possibilities with that thing! You are taking that car to the next level! All the fancy $50,000 Volts and who knows have them, and your car is going to put them to shame!
Oh, I've been working on a BMS for Thundersky batteries. I'm done with the software on the ATTinys (well, ready to start testing), and I'm getting close-ish on the dsPIC30F4011. It should cost a few hundred dollars to monitor 48 batteries. BMS systems can cost thousands easily, so it will cut a couple thousand off the price of anyone trying to affordably (hahahaha) convert their car to Lithium. It should be noise tolerant, since CAN will be used in the transmission process. I haven't started initializing the CAN module yet. It's a whopper. I did the UART for debugging purposes, and the Change state notification module, and the timer1. I've been working on the ISR for the Change State. There are 8 ports that are being watched by the dsPIC. Each of those ports are used to receive morse code about the voltage levels of the 8 batteries it's monitoring. The ATTinys read the voltage of the battery they are monitoring, and the 0's and 1's of the battery voltage get sent by morse code to the dsPIC. Isn't that a sneaky idea!? Thanks Fran! There are no noise issues, as they are right next to their dsPIC, and have a direct line to their "dad" if you will.
Old 01-18-2010, 09:44 PM   #2888 (permalink)
Hello Everyone,
I have just released a latest version of RTD Explorer. This version has a working bootloader as well as a bunch of new features. You can change the color of each line in the graph line in the settings page under File. There is also a new command list under Help. Also, when you start typing in the command box, it will bring up an auto complete box to sift through the different commands.
The updater in this version is malfunctioning badly, but should be fixed in the next version.
Let me know what you think and I would love to hear any ideas for new features you can come up with.
You can download the new version on the RTD Explorer page at www.EVVette.com.
-Adam
Old 01-18-2010, 11:49 PM   #2889 (permalink)
Hello Everybody!!
I have a chance to get some very high end IGBT modules for a very low price. Right now im trying to get a case of 600A 400A Powerex modules. These are a high end module that is close to $300 each from a supplier. I am looking for people to fill space for 4 or 5 more modules. O, and the price. $20 each!!!!! You should be able to put 2 of these modules together and create a 500A controller very easily. All you need to do is run 3 bus bars down connecting the same terminals together and add a capacitor bank to the B+ and B- terminals. These are 2 pack IGBT's so you don't need a separate one for a diode, you can just tie the gate of the second half low and use its diode. You could push 600 through 2 modules if you keep them both the same temp. You will need to mount them close together on a thick piece of aluminum.
Here is the spec sheet. http://www.pwrx.com/pwrx/docs/cm400du-12f.pdf
Please email or PM me if you are interested. I will need to know within a few days in order to get this good deal. so don't hesitate.
-Adam
Old 01-19-2010, 08:19 AM   #2890 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Do you have a thread for the progress on the BMS?
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 672 02-10-2012 05:41 PM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 527 09-02-2011 03:35 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 05:10 PM
