ok guys,
hope I can explain but first I'm not good at explining so bare with me,
the the igbts parralled has to be match'd share the same heatsink as close as possible pluss the snubbers and gate resistors all need to match as close as possible then if you want to run the cheaper igbt's from ebay there most likely can top out at around 8khz.
pluss they have to switch every single pwm cycle at near the max rating,
and you'll still get a little squeel from your motor.(unless you can afford the new igbt's with a 16-20khz rating(don't know about you but I can afford them yet ))
now imagine breaking up the pwm clock to 4 600amp igbt's who only has one pwm clock out of 4 25% load, 4 600 amp igbt's is 2400 amp split in half for a desent nominal rating of 1200amp, witch will probley never go over 500 amps during taking off and a cruising amperage of 200 amps thats only 50 amps per igbt so I believe I have plenty of derating.
now picture this you have a line of people throwing sand bags to each other down the line one 50 lb bag behind the other imagine how hot you would get, now imagine 4 of you standing there and you only get one bag then get to rest and kool down while the other three get there turn before you get the next bag again.
switching the pwm clock to 2-4-6 so on devices allow the device to run kooler and eliminates a lot of the hassels of paralleling at lot of devices together at there near max speed.
I chose 4 600 amp igbt's for no other reason exept it was a neat size and they were free I just did a little yard work for my auntie so she got them for me
the numbers were easy to work with, they can handle 8khz time 4 would give 32khz at the motor but I dont see the reason, running them at 4 khz will let them run a little kooler and gives a better signal.
motherboard manufacturers found out by phase shifting the pwm to a lot of mosfets to the cpu they could use smaller cheaper mosfets and they would run kooler, remember the sand bags imagine having to wait thru 16 people till you get your bag again.
your not going to get a heavier bag but the same 50 lb bag not a 100 lb becuase you had to wait your turn.
well hope this helps, I think a 2400 amp power section that will probley never see over 450 amps during take off and only around 200 cruise will be very safe, and above that give me very nice bragging rights hehehehe. see yaw later
got to do a 200 mile poker run today with about 200 other bikers with a police escort had to put 3 gallons back in the bike when I got home (I GOT to do something about that milage hehehe)......
